[Z06] Blackstone results question….
Hey all. I have a 2002 Z06 with 74,400 miles. I just changed my oil and sent a sample (my third one) to Blacksone Labs. The oil (Mobil 1 with a Mobil filter) had 4910 miles on it.
To keep this brief, my previous sample was nearly perfect. This time the iron and silicon content jumped as follows:
Iron: From 19 to 27 ppm
Silicon: From 9 to 53 ppm
I think the reason the silicon content increased is because I let the air filter go too long. I have remedied that by replacing it.
I suspect that the main reason the iron took a jump may be due to the increased "dirt" in the oil as evidenced by the silicon. This past winter, I replaced my valve springs with PAC1218s. Is it possible that the springs could be shedding a little material as they settle in? I don't know what they are made of.
Blackstone thinks that the silicon may be a "harmless sealer", since my other metals aside from the iron are all low.
What to you folks think? Thanks in advance for your input!
Brand new, unused, Blackstone-supplied sampling kit. I have sent many of these to Blackstone for aviation-related oil samples, and also to other analysis labs.
I just changed my valve springs and will be getting the next sample tested.... you'll have to wait until January or February but I can post results (less mileage between changes although lots of autocross passes so it does get run hard for short periods).
