Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- Why is my car losing power?
Guide to diagnose trouble with recommended solutions.
[Z06] Z06 Losing Power/Stalling
Hi folks. Has anyone had this problem? I have a 2003 MY Z06 with about 71000 miles on the clock. I took a trip last Summer - on the way back, I was stupid and didn't check the oil level. The car stopped running and gave me a "low oil" warning. It would turn over, start running, and then stop...like it ran out of gas or had the fuel shut off. Once I added oil, the problem stopped and the car ran fine. Except......
Now, on an intermittent basis, the car will suddenly lose power and stall out - and act the same as it did when the oil was low. I was driving home the other day....the car was running great!....but coming up my road, it lost power and shut down. I tried starting it....the engine turned over, started, then stalled out. I waited a couple of minutes, tried again, and the car ran fine.
What could be wrong? The oil level is fine.....I had the oil changed when I returned from my trip. Everything else seems to be running fine. Any ideas or suggestions? Thanks!
2017 Corvette of Year Finalist
2016 C5 of the Year
I would like to know as well. I haven't had that problem but I hope its a easy fix for you. Sorry I couldn't help. Maybe a electrical issue?
I've never heard of a low oil level issue stalling out an engine.
When was the last time you changed the fuel filter? What shape are the battery/alternator in?
I would start checking things other than oil level.
The battery is brand new and the alternator is fine. Voltages are normal. But I'm not sure about the fuel filter...good idea! I purchased the car last February - I haven't changed the filter yet, and I'm not sure when the previous owner did. So I'll check it out. Thanks!
Former Vendor
Doesn't sound like its anything related to oil level or pressure, have you checked for any codes in the engine control module?
And in my opinion, the oil life monitoring thing is a joke, in a performance vehicle I would never base my oil changes off of it, unless you change it at the 30% mark or something. A huge part of its programming is vehicle ownership cost; the less you have to change the oil, the cheaper it is to maintain, the cheaper it is to own, the more it appeals to people.
Feel free to call, email, or PM us anytime with questions!
- Jeremy
Click HERE to send me a PM | Sales@jdpmotorsports.com | www.jdpmotorsports.com | JDP Facebook | 888.308.6007
- Jeremy
- Jeremy
- Jeremy
Hi there. Yes, I did have some codes: P0133, P0153, and U1160. I have a set of Kooks headers on the car, and even though it was tuned, the codes may relate to the headers. I spoke with the Service Manager at Reliable Chevrolet in Albuquerque about the problem and the codes. He didn't think the codes related to the current problem. It's probably fuel-pump related. The car has now been towed to Reliable and I hope to have the problem identified and fixed by mid next week. I'll post and let everyone know what Reliable found.
The PO133 and 153 are very common with headers. Most tuners just turn them off if indeed it has been tuned.
Thanks....I'll pass this on to the tech that's working on the car. So far, Reliable Chevrolet hasn't been able to identify the problem but will continue the search on Monday with one of their senior techs.
Thanks.....and I agree.....why isn't the fuel filter in an easy-to-get-to location and easy to replace? Planned obsolescence? To ensure an expensive procedure? I love my Z06 but come on GM!!! Who engineered this situation??
I believe only 03-04 Z's have that engineering shortfall.
It's possible that you have an air leak past the MAF (mass air flow sensor), ether in the manifold or vacuum line.
Just a different direction of thought.
Been there and fixed it.
Mark.
Mark.
I just had a problem like you said with my 04 z06. After checking all electrical components it turned out to be the computer stopped telling the fuel pump relay to turn on. Replaced the computer all is good. To figure out if its that pull pump relay out and jumper the connection
Received 1,101 Likes
Best advice I can give OP is to post in the TECH forum and/or do advance search there on any mechanical issues.
As far as the fuel filters being in the gas tank...that's covered in a 33-page thread titled "Fuel leak 2004 cracked crossover connector smell", which also includes late 2003. That and many issues are include in "The best ever thread...http://forums.corvetteforum.com/show....php?t=1249213 (scan pages 1-3)
Hi folks. Reliable Chevrolet called me today. The problem.....a faulty ground circuit that affected a number of other circuits. They are repairing the problem. They also found a couple of belts that I probably could have lived with for awhile, but it makes sense to have them replaced while the car is in the shop.
A faulty ground circuit. So fellow Z06 owners, add this to your list of possible causes of firing up/stalling. I should get the car back tomorrow, and I'll let everyone know if the problem is really solved!
Gianna66 (11-14-2021)
http://forums.corvetteforum.com/show....php?t=2825794
note post #30
Once confirmed, U can also add to this
note post #30
note post #30
Moderator, Tech Contributor
Received 2,124 Likes
