[Z06] street tires c5 Z
Old 01-28-2015, 10:47 AM
04silverZ06
04silverZ06's Avatar
I emailed Michelin about the possibility of them producing the 265-40-17 in the SS and they responded that they have no plans for it.
I think the 245-40-17 will be too short - the 245-45-17 would fit, look and act better more similar to the stock 265-40-17 sizing.
Old 01-28-2015, 04:58 PM
Furiousone
Furiousone's Avatar
I'm getting ready to put the 275/295 NT05's on my car as well, good to hear good impressions.
Old 01-28-2015, 07:09 PM
Impulsive goat
Impulsive goat's Avatar
That's the only thing holding me back I don't want to be the guinea pig for the PSS but I would happily spend the money for the extra tire life over the NT05's if they were going to fit right. If not i'll go the NT05 route and just have to live with the 200 tread wear. I wonder if we bugged the hell out of Michelin would they make us a damn OEM size front tire?
Old 01-28-2015, 07:44 PM
racebum
racebum's Avatar
unless you ran square the pss sadly can't be used with current sizes
need 265 or 275 40 17
michelin also said 295 35 18 had no plans to be produced last year
BUT
they also said they plan to continue to offer something if they discontinue old. when the ps2 dies they might make it in pss. the 295 35 18 for example is only available in N4 porsche rubber in ps2, magically the pss comes in that size now.
i have no idea at all if they will make a front tire but the "no plans" email is exactly what it says. today they have no plans, next month? who knows
Old 01-28-2015, 11:55 PM
rjwz28
rjwz28's Avatar
I personally would run the 245/45-17 if I was running stock wheels with Super Sports, but some people complain about the sidewall height of the factory 265/40s, so I didn't suggest it on the chance that somebody **** would buy them, then complain about the extra 1/4" of sidewall. Either one would work just fine; both will fit a 9.5" wheel without issue, but the 245/40 falls a half-inch short and the 245/45 a half inch taller than stock. Guys (including myself) have had no problems straying further from factory guidelines than that.
BUT
There's nothing wrong with running the 245/40 or 245/45 front with a 285/35 or 295/35 rear (respectively) on stock wheels... all are close enough to factory ratio with one another that it will not unbalance the car or TC/AH systems.
Old 01-29-2015, 12:16 AM
racebum
racebum's Avatar
half an inch taller or shorter is too much imo, would require having to corner balance the car again to keep the under/oversteer neutral. taller in the front would increase understeer and a smaller tire would amplify it. also doesn't cosmetically look right
Old 01-30-2015, 05:29 AM
rjwz28
rjwz28's Avatar
You know what, I was a bit off: the difference in sidewall height between the 245/45 and the 265/40 comes to only +.17 inches. Not only that, but the diameter difference between a 275/40 and the 245/45 is only .02", meaning a sidewall difference of .01"; I don't have to tell you how many people run the 275/40 on track and street to great success and have nothing but praise for their results (the NT05 guys, for example).
I would recommend the 245/45-17F|295/35-18R Michelin Pilot Super Sports without reservation for anybody looking for an alternative performance tire with better street performance than the popular NT05.
Honestly, if it was me, I'd run the 265/35-18F|295/35-18R in PSS on 4x factory Z06 rears if I was looking to maintain the factory wheel with better rubber, but I like my aftermarket wheels so that isn't a problem.
Old 01-30-2015, 10:58 PM
LT1driver
LT1driver's Avatar
what about using the 255/40/17 and 295/35/18????
Old 01-30-2015, 11:41 PM
rjwz28
rjwz28's Avatar
That's also absolutely fine. The only reason we weren't discussing it is because the PSS isn't available in 255/40-17. What tire were you thinking about getting in that size?
Old 01-31-2015, 05:18 AM
racebum
racebum's Avatar
you could squeeze by with that
is 245 even listed for a 9.5" wheel though? that's awful wide for 265 as 8" is common for 245mm section width
do agree on street performance. the pss is a madman in the rain and rips in the dry. unless you're tracking and getting the tires over 150deg the pss is the tire to have
Old 01-31-2015, 05:20 AM
racebum
racebum's Avatar
rs3 in 255/285 has also been a popular alt selection
little better compound than the nt05
Old 01-31-2015, 05:38 PM
LT1driver
LT1driver's Avatar
conti DW if needing 17" wheel otherwise I would run the 265/35/18 and 295s which I currently have on my car and will most likely replace with same.
Old 01-31-2015, 08:34 PM
  #33
rjwz28
rjwz28's Avatar
265 is spec'd for 9-10.5" per Michelin while the 245/40-17 is spec'd for up to 9.5" and the 245/45-17 is spec'd up to 9"; however, with the extra sidewall (over the 245/40) the 245/45-17 would absolutely be fine on a 9.5", even if Michelin didn't spec it that way.
From what I've read, the R-S3 has higher dry and temp limits than the PSS, but is worse in the wet than even the NT05. It's a sweet tire, no doubt.
Old 02-01-2015, 08:20 PM
  #34
Fast Cop
Fast Cop's Avatar
Just put a set on nitro NT05's in 275/295 combo. So far so good.
Old 02-03-2015, 04:27 PM
  #35
63Corvette
63Corvette's Avatar
Originally Posted by grantv
Original wheels and tires. My rears were brand new when I bought the car last summer, the fronts need replacing which I'll do spring time. I may just switch over to a completely different tire set, but the wheels will remain due to $.
265-40-17 and 295-35-18 Goodyear F1 Supercars on factory Z wheels.
I recommend that you buy two (2) used REAR stock C5 Z06 wheels and thus run 4 10.5X18" wheels (all 4 corners) because there are more great tires available in 18" than are available in 17" and there are very few track tires available in 19" or 20". It still looks stock and the rear wheels are available on line very cheap
Old 02-03-2015, 04:36 PM
  #36
dbaker
dbaker's Avatar
Vreds on my 02Z.
275/35/18 & 295/30/19.It's a good DD setup.
Fairmont tire has them.
\db2
Carolina
Old 02-03-2015, 10:32 PM
  #37
rjwz28
rjwz28's Avatar
Pilot Super Sport 265/35-18F|295/35-18R
Quick Reply: [Z06] street tires c5 Z
