[Z06] Is Wider Better?
Old 01-30-2015, 01:10 PM
RomanNYC
RomanNYC's Avatar
Default Is Wider Better?
im trying to upgrade my tires to wider, the internet is giving me mixed signals, some say they are better some say no, what is the deal with wider tires....? i have a 2003 z06.
Stock is 265F / 295R
Want to upgrade to 275F / 305R
what is the ups an downs of the upgrade im considering?
Old 01-30-2015, 01:47 PM
grantv
grantv's Avatar
Default Very little difference.
In theory it will be minutely slower off the line (heavier tires, larger OD, although potentially offset by more traction), and higher top speed with better highway mileage, but both probably not measurable. At least not seat of the pants. Unlikely you'll have rub issues as many run as big or bigger.
Old 01-30-2015, 01:53 PM
WannaC5Z
WannaC5Z's Avatar
Only 10mm wider isn't anything to concern yourself with. Over that be sure your aspect ratio remains close to OEM or your speedo will be off and the TC may malfunction.
Old 01-30-2015, 02:16 PM
RomanNYC
RomanNYC's Avatar
alright thanks, im not sure if my calculations are correct, but this is what i came up with.
275 / 40 /18
305 / 30 / 19
is there any performance increase in going with staggered sizes, i dont mind getting 18's all around but than again since gm kept it staggered i figured they ran the tests.
Old 01-30-2015, 03:26 PM
grantv
grantv's Avatar
The computer wants about 3/4" larger overall diameter in the rear.
Anyway, I didn't see you wanted to go +1 on wheel size...
Factory:
265-40-17 = 25.3" OD front
295-35-18 = 26.1" OD rear
Front:
275-40-18 will be 26.7", not right.
265-35-18 = 25.3", 275-35-18 = 25.6", both OK
Rear:
295-30-19 = 26.0"
305-30-19 = 26.2", both OK
Old 01-30-2015, 04:07 PM
RomanNYC
RomanNYC's Avatar
Factory:
Front:
Rear:
295-30-19 = 26.0"
awesome, thanks alot!
Old 01-31-2015, 08:48 PM
rjwz28
rjwz28's Avatar
Compound matters a lot more than width. For example, a Hankook R-S3 in 255F|285R is much more grippy than the factory Goodyears in 265F|295R. If you're going +1, 265/35-18F|295/35-19R or 275/35-18F/305/35-19R are both great. Many people (including me right now) run the 265/35 up front with the 305/30 out back with nothing but good results. If you're looking for a solid three-season performance tire, I recommend the Pilot Super Sport. For fair-weather use only and a bit more bite in the canyons and the occasional autocross or track day, the Hankook R-S3 is excellent. Both are in the same price range for a set ($1200 or so, maybe less)
Old 02-04-2015, 10:14 PM
bluestreak63
bluestreak63's Avatar
Just curious...why do you want to go wider? Because of tire make/model availability?
To Is Wider Better?
Quick Reply: [Z06] Is Wider Better?
