[Z06] 16" rims in rear?
16" rims in rear?
can you fit a 16" rim on the rear of a c5z? looking to run ET street 26X11.50-16 thats on a camaro rims
do able?
Edit: in case some one else ever needs to know
I was able to get the wheels on the car, I had to hammer the top of the ball joint down a little and do a "little" grinding on the rear hubs but as you can see there on
this pic is the two spots that needed to be grinned down not much though, really just the tops and a little of the curve area, I marked the area with a marker then would spin the wheel to see where it was touching then would grind a little and repeat till it was not touching any more taking my time about an hour start to finish
do able?
Cruise-In IX Veteran
Yes, with the CCW drag pack they are a 16" rear wheel. You may have to dimple the top of the upper ball joint cap. I think CCW has instructions on doing this though.
i'm not sure witch one that is? the tires I got are already mounted on camaro rims 93ish directional split spoke
