[Z06] Z06 Brake Ducts
Z06 Brake Ducts
Looking into installing some Z06 brake ducts on an frc. I'm wondering what does this entail? Are the parts costly? Thanks folks.
Wasn't aware there are stick ons. Just basically doing it for looks so stick on would be fine.
Stick on ones look terrible...I put a set of real ones on when I had my 2000 Vette. I bought all the parts from GM and made them functional. I believe the cost was about $250.00 for everything including nuts and bolts. I used a template and cut the rockers with a dremel. You also have to pull out the inner wheel well covers and cut them for the duct work. The area you need to cut is already marked by GM. Whole job took maybe 3 hours. Good Luck!
Yes please if your gonna do them do em right. The stick-ons look terrible. There is a template to print out so you can cut the hole in your rocker properly. But once you go scooped, you cant go back.
10322761
10322762
Go to amazon for the oem AC Delco scoops
10322761
10322762
10322761
10322762
Amazon.com: ACDelco 10322761 GM Original Equipment Rear Driver Side Disc Brake Caliper Cooling Air Scoop Assembly: Automotive
Amazon.com: ACDelco 10322762 GM Original Equipment Rear Passenger Side Disc Brake Caliper Cooling Air Scoop Assembly: Automotive
10322761
10322762
