[Z06] How did you weld steel cutouts to stock TI exhaust?
I am ready to order electric cutouts, but I know that steel and titanium do not weld together. How do all of you with E cutouts do it with the titanium exhaust?
They probably have it welded in their x-pipe, which is steel of course.
I am determined to install the cutouts as close to the cats as possible. I know this seems impossible but I am going to try everything I can to do it. Will definitely post up all my trial and errors throughout the process.
Alright well this brings up the question, how is the X pipe in place with a TI exhaust? I assume it has to be clamped? And if that is the case, cant I just simply weld a small 2.5" ti pipe on my exhaust (since my cutouts do not come with a Y pipe), and then clamp the cutouts to the new ti pipes? Any reason that wont work?
Only the rear section is titanium. The 1st 2/3rds of the exhaust is steel, and the cats are in the middle of that steel section. There is no need to mess with any titanium, especially considering your goal.
Cutouts
Philad is correct. I just had cut outs installed and they were positioned in the Stainless portion, right at the Y pipe. Work perfectly there is another thread Ive seen here where there are pictures of both popular types of Cutouts after being installed. if I can find it I'll advise where thanks
pics
Philadd is correct. I just had cut outs installed and they were positioned in the Stainless portion, right at the Y pipe. Work perfectly. there is another thread Ive seen here where there are pictures of both popular types of Cutouts after being installed. if I can find it I'll advise where thanks
I'm not sure you've looked at your exhaust before. The exhaust piping is steel from the exhaust manifiolds, past the cats, to just before the over-the-axle pipes. It connects via flanges to the titanium over-the-axles pipes and titanium mufflers.
Cruise-In IX Veteran
You want to put them under the transmission. See this, they have pictures.
https://www.google.com/url?sa=i&rct=...29907411996774
Search for pics and you will find a ton.. here is a post about the same questions and has pics.
https://www.corvetteforum.com/forums...-cut-outs.html
If you are running straight pipes I don't think you will hear much of a difference. Depending on the exhaust system you have under the trans is a good spot. With aftermarket headers and 3" piping you run into a restriction right where the mufflers bolt on by the trans/diff. On my car I see a notice increase in midrange torque with the cutouts open due to optimal placement for the exhaust pulse to exit.
Looks good. Those are the one I had on my GTO, except I want them much further towards the front of the car than yours are since I have straight pipes.
I had straight pipes + x pipe on my GTO and I had the cutouts just after the cats. There was definitely a noticeable difference. If they were mounted closer, near the transmission for example, yes the sound difference would be less noticeable. I also want them to be near the cats so that they are BEFORE the X pipe as well, as that would change up the sound quite a bit. I don't plan to do aftermarket headers or 3" exhaust anytime soon. Might be shooting for a C6z by the end of the year. Thanks for the input!
I put mine here so I didn't have any drone under the car and all the noise goes straight out the back. My car is cammed out with headers and absolutely screams when the cutouts are open. I set alarms off when I pass parked cars
Hands down the funnest mod you can do to any V8. The best part is that not many people know about switch operated cutouts, so the shock factor is always fun.
Well, I told you I would find a way. Mounted these just before the cats. They hang down about an inch total, which is fine since my car isn't slammed all the way down. Being that these are mounted just before the cats, you can imagine that this thing is louder than holy hell.
