[Z06] Brembo brake kit & formula 43 wheel package 97-04 c5/c5zo6/
Former Vendor
St. Jude Donor '13
BREMBO BRAKE KIT & FORMULA 43 WHEEL PACKAGE 97-04 C5/C5ZO6/
Road Race Brembo Brake and Wheel Package
Kit Includes:
(1) Set (Front) 6-Piston Red Calipers | 350x34 mm (14") Type 3 | 2-Piece Discs
(1) Set Stainless Steel Braided Brake Lines
(1) Set of Mount Hardware
(1) Set of Caliper Brackets
(1) Set (2 Rims) Front Formula 43 Rad 10 Club Sport 18 x 10.5
(1) Set (2 Rims) Rear Formula 43 Rad 10 Club Sport 18 x 12
(1) Set of 4 Rims Matte Black Powder Coated Center and Lip
Wheel Weight 22 LBS each
Offset Made to Clear Brake KIt
Your Price: $7,595.95
Brembo 2-piece discs are made up of an advanced cast-iron alloy which offers an exceptional coefficient of friction and resistance to thermal shock and fatigue. As the braking system's primary function is to dissipate heat, larger, more sophisticated discs are used in order to increase the fade resistance of the system. These discs are directionally vented for enhanced cooling, as well as drilled or slotted for improved consistency, continuously cleaning and refreshing the pad surface.
Type III High Thermal Disc
Rotary Forged
Formula 43 modular wheel center sections use a Rotary Forged process that results in a superior tighter, circular grain structure. The rotary forged center section begins life as a cylinder of billet. The billet is then heated and placed into a die in the rotary forging machine. The die spins the billet at 300 RPM while the billet is pressed from above at a 5 degree angle. The material then flows in a circular pattern into the die. The new forging is then heat treated, quenched and aged to T6 standards. The end result is a rotary forged center section that has stiffer spoke dimensions, lighter weight and a quicker moment of inertia.
Formula 43 Spin-Form
The Spin-Form process developed by Formula 43 is a specific method in spinning 6061 aluminum circular sheets into 2 piece rim-halves. The computer controlled German spinning machine uses four rollers to form the inner and outer rim-halves on tooling designed in the shape of each rim-half. The Formula 43 method is a three step process: (1) spinning the part.
(2) heating and aging the 6061 rims to T6 condition and
(3) re-calibrating the rim-half after heat treating to ensure a very low run-out of the part.
Along with the Formula 43 process, several changes to the rims have been made to better fit and perform with today's modern racing and sports cars:
1. Improved safety bead on both inner and outer rims to ensure proper seating of the tire so that the tire will stay mounted to the rim in the event of impact or loss of air pressure.
2. Improved rim contour to help ease tire mounting and bead seating.
3. Added material in specific areas of the rim-half for additional strength and stiffness.
4. Drop center contour updated for proper TPMS fitment and installation without having to add additional brackets or modifications. The end result is we've engineered and are able to manufacture a high quality, performance wheel line. We've even submitted our wheels to an independent testing facility to see if they can hold up to demanding SAE Certification in 18" and 19"sizes, as well as Impact testing for both 18" and 19".
http://www.xplosiveperformance.com/B...O6_p_3632.html
Former Vendor
St. Jude Donor '13
Kit Includes:
Rotary Forged
Former Vendor
St. Jude Donor '13
Kit Includes:
Rotary Forged
Former Vendor
St. Jude Donor '13
Kit Includes:
Rotary Forged
Former Vendor
St. Jude Donor '13
Kit Includes:
Kit Includes:
