[Z06] Stainless Steel Headers Made In USA for Under $1000 Shipped @ Hinson Motorsports
Former Vendor
HINSON Motorsports is proud to offer the only ceramic coated stainless steel header built in the America under $1,000. The HINSON Motorsports C5 header systems are proudly built in the USA from stainless steel and then ceramic coated for lower under hood temperatures. Our ceramic coated stainless steel headers use mandrel bent 1 7/8" tubing and 3/8" flanges for a precision fit and finish.
Features
Stainless Steel Construction and High Temp Ceramic Coating
Easy installation for both wet and dry sump applications
1 7/8" Mandrel Bent Tubing for peak exhaust flow
3" Collectors
Lower under hood temperatures than non-ceramic coated headers
Slip fit collector for easy connection to a performance X-pipe
Ceramic Coated X-pipe for reduced center console temperatures
Direct fit application - No fabrication required.
Includes O2 Extensions ($50 value)
Includes
Ceramic Coated Stainless Steel Headers
Ceramic Coated Stainless Steel Header Extensions
Ceramic Coated Stainless Steel X-pipe
Stainless steel rear axle back connection pipes
O2 Sensor Wire Extensions (x2) $50 value
Clamps
Ceramic Coated X-Pipes for reduced interior temperatures
Installed prior to ceramic coating
In stock and currently being ceramic coated. Anticipated ship date of July 27 2015.
Former Vendor
Just a few more Q's:
Will they eventually be offered in 1 3/4? What years have they been test fitted on, because I think different years have different fitment issues ( I have a 2004)
Thanks!
Thanks!
Former Vendor
We have no plans to do anything but the 1 7/8". Headers have been fitted on all Z06 and base model C5's without any issues.
Former Vendor
Former Vendor
