[Z06] what is this noise....from my buddies z06
if nothing is in the fan, have him check the rockers. I broke one coming back from Carslile PA at 3 in the morn and thought is was an engine.
its definitely rotational and we disconnected the serpentine belt and it still made the noise.. it goes up and down with engine RPM
I would pull the covers and inspect the rocker arms, check valves, compression test for cylinder pressure. I'm not a mechanic but I've had these problems
thanks for the ideas.....so far the rocker arms look good and it doesn't make the noise when cranking with all the plugs out of the engine......
Weird, on my little crap speakers it sounded like an exhaust leak. Did this just start? Any mods or work done before it started? ...
no new mods and it sounded and ran well before then all of a sudden when it was idling this started...its definitely rotational almost like spokes in the wheel.
The engine is struggling to spin, I think the the spun bearing is the winner.
I would be there isn't much left of the shell in the big end of the rod.
I would love to hear more of the engine running, but I don't think it has too long to live
I bought an LS3 out of a camaro and installed my cam, headers, intake, and other parts that swapped over. I also drysumped it trying to make it bullet proof. LS6's are pretty hard to come by but a used LS3 block is pretty cheap
