[Z06] New Tires '03 Z
New Tires '03 Z
Guys, old topic, need new tires for the Z , have been on computer & phone all afternoon ,looks like the choices are slim , any advice from the Pro's here on the Forum ! Thanks in advance !!!!
Pro Mechanic
I went with Nitto NT-05's (275/295) last summer and have been very pleased with them...
I've been happy with my Bridgestone RE760's. Smooth, and quiet. They grip well, but I don't track my Z06. Some have said if you intend on pushing the car to its very limits you might want to spend twice as much and go with Michelins.
I agree with bridgestone 760--likely for stock sizes the best riding tire money will buy--alittle under 800.00-mounted balanced out the door at discount tire--if your going to drag race from a standing start--have him give you 2 car lengths head start--call it the "Bridgestone start"
I really wouldn't consider another tire unless I decided I would avoid driving in rain COMPLETELY and step up to the NT-01, or if I felt like spending an extra $4-500 (unlikely) and get the Michelin PSS or PS2 whatever it is that fits.
The RE760's are not befitting of a Z06 - this has been discussed numerous times, they ARE NOT geared toward the performance level of the Z. An auto convertible w/ the 2.73 rear end? sure. Z06? NO.
Same price as the Nitto NT05 I see zero reason to choose the inferior tire from a performance standpoint.
FWIW - grip in the rain is fine w/ the NT05's as long as you don't drive like a moron, they are not suited for temps below 45-50 degrees though
Continental Extreme Contact DS are a great value spirited driving tire.
I see that Goodyear has brought back the GS-D3. I had those on my C4. They have been my favorite tire on a Vette.
When I next need tires that is what I will buy, now that they are again available.
Meant to add that you can go up to 315's both front and back without fitment issues if your Z is not lowered.
The wider you go in the front the more the tire is prone to roll over and suffer from premature edge wear if you corner hard. I have had no edge wear issues at 295 up front, but it starts at 305 and accelerates at 315
New Tires '03 Z
If you install a wider wheel, you won't have that problem with the tire rolling over, but you'll have more clearance issues
Everyone has a different opinion but I have fallen in love with my Bridgestone RE11 tires. They provide all the confidence you need in your tires. They are priced a little higher than some others but you get what you pay for!
I know they are R-comps but I drove around with Nitto NT555RII's for awhile and that was awesome. They hooked instantly and I couldn't spin going into 2nd at all.
My next set I will be eyeing the NT-05's.
Has anyone considered these for the rears. Michelin makes a direct replacement for the fronts in PS2 but the only option in stock sizes for the rear are these. I have not seen many comments here about these.
http://www.tirerack.com/tires/tires....omCompare1=yes
