[Z06] moog sway bar end links - greaseable??
Last night scouring the web looking for some parts to upgrade/replace on the Z's suspension this winter I compiled a list finding the part #'s I needed & at the best prices I could find - rear inner/outer tie rod ends, front outer tie rod ends, front/rear poly sway bar bushings, and even the damn rear sway bar bushing nuts/bolts - mine are all bound up/rusty (oddly enough my butt is most sore from that purchase - $48 for a total of 8 nuts/bolts from ecklers...ridiculous)
BUT - for the life of me I cannot locate where I found the MOOG sway bar end links I wanted to order. I can locate the solid non adjustable ones, but I SWEAR I found a moog sway bar end link replacement that was solid, enclosed, and allowed for greasing.
Really bummed out because I wanted to get it all ordered @ the same time - if anyone can help will be appreciated!
I installed non-adjustable, greaseable Moog links about a year and a half ago on my 2002 Z06. You can still get them at Advance Auto stores. That's where I got mine.
BTW-these were for the rear end. I also installed an Eibach sway bar at the same time. My factory sway bar was corroded.
Hope this helps!
Hope this helps!
Last edited by Zealot06; 11-27-2015 at 08:49 AM. Reason: Remembered another detail
got them thanks
