[Z06] Clutch return spring
Installed a Lingenfelter clutch pedal return spring today. Not that difficult of a job as long as you are patient. Hope it works. Clutch pressure not increased much.
Clutch spring
Took the spring out on my c6 and it’s definitely harder to push the pedal I’ve got a twin plate clutch so pedal spring definitely makes it’s easier to push the pedal down especially if stuck in traffic it’s going back in
doesn’t the spring make the pedal harder to push, since it’s a return spring that applies upward pressure?
Received 1,869 Likes
Reviving a 9yr old thread, in the wrong forum, is a heckuva 1st post.
Received 19,291 Likes
'20-'21-'22-'23-'24
Closed.
