[Z06] My "fix the small things" winter build
#41
They transformed my car honestly. Once I get more miles on them, I will post a better review. There is a 1/2 and 1 mile event locally in 2 months and I want to get a good DR and setup the suspension for it. Then hit the drag strip and see if I can get it to squat.
#42
^ Do you have any more details on that Olean event? Looks promising but at the same time somewhat unorganized. Last I heard they didn't have any timing equipment or radar guns set up.
#43
Not any more than whats posted in that disaster of a FB thread. It's amazing how stupid people are (can I run bald tires?). Radar guns would be a huge win, but if not then it will be a roll race event. I expect 60% of the cars showing up to be complete trash.
#45
Should be "interesting"....expecting a lot of the stance boy vapers to be confused as to why they spun out at 80mph
#46
It's been a while but progress has slowly been made. I ended up purchasing a set of 275/40/17 ET Streets and can finally hook 3rd gear. A pull from 2nd gear wasn't on my list as I was fairly sure the manual idler bearings were toast. Removed the idler and the bearings fell right out (after c-clip removed), had a very nice rattle to them, and the grease was all over the idler. Purchased 2 new bearings from Amazon, and Jay (local shop) helped install them with green locktite. I initially thought they needed to be pressed in, but light tapping did the trick.
Also I am thinking about getting a shorter belt, the length I received with the kit stretched a decent amount and it almost seems like on hard shifts it wobbles resulting in 1 rib being off. I did laser align the belt system and it was within specs.
For the shroud I waited on a set of metric drill & tap bits. Using self tapping screws seemed like a ****** idea. It will be held down with some M5 x .8 bolts instead.
#49
Were you making passes at Lancaster last night? There was a black C5Z that was doing work and sounded great.
#50
I believe that was Brian (heads/cam + nitrous), I had my blower off my car last night to fix the idler. Without bias-ply tires I doubt I would hook at lancaster without prep.
#51
Gotcha, hope to see this thing out soon.
#52
Tomorrow I'll throw it back together and I still have the 17s on for more fun Should be at mighty Sunday night and cruising the other days, shoot me a message if you are out.
#53
How about rivets for the shroud? I have done it before and they hold great and if you need to remove them a drill bit makes quick work of them
#54
Always down for beer and boost
#55
Bumping this thread from the dead.
I finally got around to installing the new shroud. Drilled/tapped the rails for M5x.8 bolts so everything is easily removed for inspection/repair. Couldn't find any decent prices for drill/tap combo from the states, ended spending less for a Chinese set. Sad but $30 for a single bit is nuts.
