[Z06] Corsa muffler clamp keep getting lose
Hi all, I need some help with the Corsa muffler installed on my '03 Z06. A few months ago after about 7 autocross runs in one event the driver side muffler fell off. I reinstalled the muffler but after another 4 autocross runs last week the clamp for the same muffler came loose again when I checked it after I got home. It didn't fall off I guess because I only did half the runs and I checked it right after I got home from the event but I had to loosen the clamp bolt and tighten it. Even after I re-tighten the clamp I feel like the pipe that goes into the muffler didn't go deep enough, if that makes sense. The thing is the passenger side looks fine and never got loose. Other than the Corsa cat back the rest of the exhaust from the header to the X-pipe are stock.
Has anyone else experienced this issue before? Is it possible that the pipe that goes to the muffler for the driver side is shorter than the one for the passenger side? Anything that I can do to push that pipe to go into the muffler deeper? Thanks for the input guys.
