[Z06] ***ALL New Dedicated LED DRL from Radioflyer Innovations***
Supporting Vendor
Bring them into the 21st century with these high-powered Morimoto X.DRL.1 LED dedicated DRLs. These lights replace the factory fog lights which are pretty pointless. These new DRLs are incredibly bright and will provide an added level of safety and visibility for your low-profile corvette.
The system comes with Radioflyer's Plug-and-play White DRL harness and Cree LED turn signal bulbs. Function is completely automatic. When the turn signal is activated, the DRL on the signal side will shut off until the turn signal is deactivated. (see demo video below)
Video explanation of functions here:
Also included with the kit is our hyperflash harness to maintain the factory turn signal flash rate. If you already have this installed, you can remove it from the package.
If your car did not come with factory fog lights, no problem. You can purchase our fog light brackets with stainless steel hardware for an easy bolt-on installation.
DRL performance Photos
Test conditions:
Overcast late morning. LED was mounted at roughly the same height as the fog lights on a C5 and positioned in a cardboard box to simulate the fog light cove area. The large cardboard behind the test setup is to allow the camera to see the fog light apart from the white garage door.
10ft from light
25 ft from light
50 ft from light
100 ft from light
approx 200 ft from light
Rough guesses show a uniform beam pattern of about 50 degrees spread both horizontal and transverse. This means that even on uneven roads or turns the DRLs will remain evenly visible to other drivers.
Order your set today:
http://shop.radioflyerinnovations.co...system-099.htm
Test conditions:
10ft from light
25 ft from light
50 ft from light
100 ft from light
