[Z06] 2001 Z06- Motor not Toasted,
Thanks for all the help, and suggestions. It turns out that instead of a bearing, I had to replace a broken valve spring,Rocker arm, lifter and pushrod....
I ended rebuilding both heads, and replacing the valve springs....She runs great, but started throwing codes.
P0141 bank 01 sensor 02
P0332 Knock sensor
C1214 ABS
the car sat for 8 weeks....
will these codes effect performance, fuel economy etc....it might be a couple of week before I can get them fixed.
P0332 Knock sensor
C1214 ABS
Throwing it out there... but is the battery fully charged? Are all codes followed with C (current as opposed to H history)?
I do not know if they are current or history, I am just going off what mechanic told me. Battery is new. check engine light is on, it was not on before.
Check the codes yourself. Look for the C or H. I had a few codes in H when I bought mine. Cleared them. Never came back. Some codes will pop up if battery power is lost or too low. That's all. I figured the H codes on mine surfaced when the battery was replaced, creating a loss of power and communication with sensors and controls.
P0141 bank 01 sensor 02 Yes
P0332 Knock sensor. Yes
C1214 ABS. No
C1214 ABS. No
Get in, close door, turn key to on (do not start).
Click reset on DIC
Hold options button down while hitting fuel button 4 times
Presto; all codes will pop up. Write them down including suffix, post here.
