[Z06] 02 Z06 mild cam with no headers results
And that's with a small cam - what if the cam was a stage 3 BTR, not even the stage 4. Plus a nice set of aftermarket heads (trick flow or afr's) & fast intake, headers. That car is chocking a bit without headers for sure.
It could hit 500 whp on a mustang Dyno. Whats that on a dyno jet?
Eating LS7's for breakfast. Wasn't 2002 Z06's the best year?
From the back, the exhaust drowns the cam sound. You can hear it from any other direction though. If I ever decide to get headers, the borla straight would have to go.
So I guess right @ 400whp CAI/cam only sorta makes sense & w/ full length headers breathe even better gaining an extra 20-30whp seems plausible for sure
albodent (10-04-2016)
Banned Scam/Spammer
Received 1,319 Likes
One caution with high lift springs is to make sure they are up to temperature before you give much rpm. One can break and ruin your month.
I mention this because you say it's a daily driver. Easy to be running a little late for work one winter morning... crank the car and at the intersection you can dodge a long line of traffic by gassing it just a bit... and little did you know you just cracked an inner spring.
I've got nearly the same cam and love it. Avatar picture is the engine.
Your engine looks like it makes just a hair of hp over mine
