[Z06] What is this sensor on the tranny? (Pic)
Found a leak coming from one of the sensors on the tranny. Can anyone tell me which part this is so I can replace the sensor or the gasket? The car is a 02 z06. Thank you!
Also. It may just be loose. Chances are it dosent take a gasket. I would pull the sensor first and clean it and the hole it goes into real well. Then use some Teflon tape around the sensor threads and put it back in nice and snug. I'd start there. If the sensor is not malfunctioning then there is no reason to change it. Try that first before buying a replacment.
Thanks! That's the thing where it makes u shift from 1st to 4th right?
The car already has the CAGS mod done. I still see the shift light come on when I roll in first gear. Should I remove the sensor and plug it? I don't see the point of buying a replacement sensor when I don't need it, right?
Thanks! That's the thing where it makes u shift from 1st to 4th right? The car already has the CAGS mod done. I still see the shift light come on when I roll in first gear. Should I remove the sensor and plug it? I don't see the point of buying a replacement sensor when I don't need it, right?
DK83 (01-19-2017)
