[Z06] Get Your LS7 Clutch Kit & Fidanza Aluminum Flywheel Option From CULTRAG Performance
Premium Supporting Vendor
Hello All,
Thank you for your interest in our LS7 clutch kit. Many people ask us how much horsepower this clutch can hold. GM doesn’t have any official numbers but you can count on 650 horsepower. We have not had any reports of issues with this in any vehicle, unless you take it to the track and constantly dump the clutch. If you’re dragging the vehicle, then you need a different clutch.
With the 2004 Z06 GM updated the slave and master cylinders for a bigger bore to allow more fluid flow. The slave and master cylinders that we sell are only the 2004 Z06 and fit all C5’s from 1997-2004. The slave cylinder also comes with a new throw-out bearing. We recommend a new pilot bearing when installing as well.
To order, please call 484-334-8833 or go to the link below to ordering using our LS7 clutch kit configurator system.
Thanks. Gene.
Order LS7 Clutch Kit Link!
http://www.cultragfactoryparts.com/c.../ls7clutchkit/
Our independent in house weight test results were stock LS7 flywheel 26 lbs. 11 oz. and the Fidanza aluminum flywheel 13 lbs. 5 oz.
||--Genuine GM C6 Z06 LS7 Clutch Kit--||
24255748 – LS7 Clutch
12571611 – LS7 Flywheel
Both LS7 Clutch and LS7 flywheel are $509.99 total.
For both clutch and flywheel on our website, use part number ls7clutchkit under Chevrolet make.
We are now offering the LS7 clutch kit with the matching Fidanza 12.9 lb. aluminum flywheel.
Comes with LS7 clutch disc, pressure plate, alignment tool and Fidanza flywheel - $749.99
24264180 - LS6 Slave Cylinder – $152.24
12564455 - LS6 Master Cylinder – $154.99
14061685 – Pilot Bearing – $15.69
*Clutch does work in any LS1/LS6 drive train but must also have ls7 flywheel.
Also, you can only use LS1/LS6 hydraulics, not LS7 hydraulics.
We now also provide a clutch alignment tool with the kit and the kit from GM does not come with this so we have added it for your convenience!
Thanks. Gene.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
D shaped steering wheel
Hey Gene, do you offer forum discounts on your C7 D shaped steering wheels? I'm looking for the red stitched, carbon fiber lower section if you have them. Thanks
http://www.cultragfactoryparts.com/c...l/?parent=1001
I never had a Aluminum flywheel ,back in my old C-4 days people well some liked them some not so much for street use . Can you give some input on the effects in driving with Alum. over the steel flywheel for street ues .. Thanks..
Some say easier shifting and definitely quicker rev. You can do some research on the topic and get a feel from many people and their experience so that you can form your own opinion.
I purchased new shocks from you guys a couple months ago for my Z06 suspension transplant. The shipping was quick and post install I'm super happy with the results! I do want to ask though, do you have experience with this pairing? The LS7 Stock clutch and pressure plate are extremely heavy, and pairing them with a very light flywheel seems like it would make the car kind of rough to street? I'm planning to do a clutch and flywheel upgrade in the near future, but I also daily my car and would like to know if I'm going to need to step on it every time I let up the clutch? Do you have some direct feedback from any of your guys or customers?
Thank you for your orders they are much appreciated!
__________________
Patrick Trageser
CULTRAG Performance
Your one stop source featuring the true experts for all GM Parts and Accessories, Lloyd mats, SLP Performance and Hawk Brake pads!
Order Your GM Parts at www.CULTRAGfactoryparts.com
patrick@cultragperformance.com
1-484-334-8833
CULTRAG Performance
1-484-334-8833
