[Z06] Mini tub and trunk partition.
Hey guys. Im in need of a trunk partition that will work with LPE tubs. Ive seen some foam pieces but not sure if they could be manipulated enough to fit. Whos running one and where you get it? Thanks.
Ive seen that one. However its made out of a board. I cant imagine it would squeeze between the tubs. I lost almost an inch on both sides with the tub.
I made my own out of 2" rigid foam board, adhesive spray and interior fabric from an auto parts store that was a perfect match. Weighs like 2 lbs and cost around $50 or so in material. Looks factory.
2" rigid foam insulation board (lowes or HD). Used a piece of card board to trim to the shape needed then cut the foam board to shape. Interior fabric was from pep boys, it was a perfect match, think Auto zone sells it too. Adhesive fabric spray from any auto parts store. I already had the fabric and spray from a previous car project, all I needed for mine was the foam.
