[Z06] C5Z Rear Window Rattle
My rear window rattles and it's driving me crazy. If I push it from sitting in the drivers seat it has a little bit of play. Basically, that "play" is causing the rattle. What's the best way to secure the window back to the car? I know they make some sort of JB Weld product that can do it but I forget what it's called and where I saw it.
I would talk to an auto glass specialist and see what they use / recommend. Never heard of a rear window becoming loose other than convertibles. Are you sure the glass is moving and not just transmitting the sound? I'd also be worried about water leaks.
No water leaks. I guess I wouldn't call it loose. If I push and pull against it it doesn't really move but it rattles/creaks right where it contacts the body. I might try some grease there.
