[Z06] Steering Wheel Replacement
Old 11-26-2016, 08:11 PM
apache88
Cruising
apache88's Avatar
Default Steering Wheel Replacement
Has anyone replaced the steering wheel in their c5 with something like a MOMO or equivalent. I know this means eliminating the wheel air bag. Is there a way to keep the air bag light from coming on.
Old 11-27-2016, 01:33 PM
kirk tarrant
kirk tarrant's Avatar
just did a sparco in mine,
uses a resistor but i can not recall the spec
Best mod so far lol
car feels so much better!
Old 11-27-2016, 02:19 PM
skydiven4fun
skydiven4fun's Avatar
St. Jude Donor '13-'14-'15
yep sure have
Old 11-27-2016, 06:34 PM
baddboyz03
baddboyz03's Avatar
SKY,
how about some info??
hub used?
resistor to keep airbag light off?
etc
thanks
Old 11-27-2016, 08:22 PM
apache88
Cruising
apache88's Avatar
Default C5 steering wheel
Thanks for the replies. I'm on the fence right now with how I want to proceed. I understand there may be some liability issues removing the air bag and the stock wheel may be difficult to remove. I'd also like to know how to wire in that resistor.
Old 11-27-2016, 08:24 PM
kirk tarrant
in canada air bags are not required,
i used a nrg hubb but i will require a 1 inch spacer.
Old 11-27-2016, 08:51 PM
skydiven4fun
Originally Posted by baddboyz03
SKY,
hub used?
etc
thanks
I will have to do some digging on the hub used, Stephan at Englandgreen got it for me, its an aluminum hub, my wheel came with a resistor kit that Momo offers, it was a pretty straightforward install, I have read that some are having real issues removing the old wheel, The main thing is use a quality wheel puller.
Old 11-28-2016, 12:43 AM
FYRARMS
FYRARMS's Avatar
Received 3,220 Likes on 1,583 Posts
There are several threads about installing aftermarket wheels, including what people used for the wheels, adapters, and air bag resistors. Most are in the C5 General and Autocross/Roadracing forums. A simple search will provide lots of links.
apache88 (11-28-2016)
Old 11-30-2016, 03:00 AM
chain_5001
chain_5001's Avatar
A 5 watt 2.2 ohm resistor is what I use. I just stick the leads into the wire harness where it plugs into the airbag and zip tie it up so it doesn't come loose.
Old 11-30-2016, 06:33 PM
apache88
Cruising
apache88's Avatar
thanks again for all the feedback. Great stuff. I ended up sending my wheel to vette essentials to have it redone by them. Great people to work with.
Old 12-02-2016, 02:40 AM
JETZ
JETZ's Avatar
Like that Momo, have one in my boat.
frank
Originally Posted by skydiven4fun
yep sure have
Old 12-04-2016, 10:04 PM
baddboyz03
baddboyz03's Avatar
SKY thanks for the info
Old 12-17-2016, 09:25 PM
383 Z06
Racing
Support Corvetteforum!
383 Z06's Avatar
St. Jude Donor '09
I would be curious to see some more updated pic of some aftermarket steering wheels....
Old 12-17-2016, 10:38 PM
JETZ
JETZ's Avatar
You would not be able to get this wheel, but here is the 'Raid' SW with a functioning air bag installed in a forum members car in Germany.
frank
Old 01-04-2017, 12:20 PM
383 Z06
Racing
383 Z06's Avatar
St. Jude Donor '09
I have looked on NRG website for the NON-quick disconnect c5 hub/adapter and can't find it listed? Does someone have an alternative vendor or link?
Old 01-05-2017, 12:53 PM
work_truck
work_truck's Avatar
Originally Posted by 383 z06
i have looked on nrg website for the non-quick disconnect c5 hub/adapter and can't find it listed? Does someone have an alternative vendor or link?
nrg srk-170h
383 Z06 (01-06-2017)
Old 01-05-2017, 02:01 PM
383 Z06
Racing
383 Z06's Avatar
St. Jude Donor '09
Originally Posted by work_truck
nrg srk-170h
Oh perfect! So with just that single piece I should be able to connect and aftermarket (sparco, OM, whatever) race wheel to my existing steering column? Sorry to beat a dead horse here just want to make sure I'm not coming up short
Old 01-06-2017, 02:12 AM
chain_5001
chain_5001's Avatar
Yes & no. It depends on the steering wheel you are installing. It needs to have enough of a dish to clear the turn signal and and wiper stalks. With a flat steering wheel you'll need some kind of spacer or a quick release. I think most people opt for the quick release. It doesn't cost that much more than a spacer and adds the quick release function. I have the NRG hub, NRG gen 2.0 quick release with a momo monte carlo steering wheel. iirc it move the steering wheel about 1 inch closer to the driver. Not very noticeable. What is more noticeable is that your turn signal stalk is now 1 further away from your fingers. Not a big deal but it does take some getting use to.
Old 01-17-2017, 08:33 AM
spitfun
spitfun's Avatar
Default Momo GT-50 Steering Wheel
I always liked this wheel,think it would look at home in my C5. Rich
To Steering Wheel Replacement
Quick Reply: [Z06] Steering Wheel Replacement
