[Z06] a question about new vs old cam grinds
ive been looking at ms4 and g5x3 cam result threads and i see alot of people referring to those cams as old grinds and old tech. what cams would anyone say have replaced these two??
I have actually heard this a lot recently as well.
I was asking about the same cams, MS4, MS3, G5x4, GM cup cam.
Are old cam profiles not as good as the newer cam profiles? and if so, why not?
Cylinder heads and intake manifolds are better today then 10-15years ago. You can afford to use less cam to get similar power results with better driveability.
Jeffdenney (03-14-2017)
All those cams made power then and they will make power now. IMO, over time it seems vendors have learned to make similar power with lobes that are mellower on your valvetrain, getting some more life out of springs.
Talk to Tony Mamo. He can custom grind you something.
You will notice it for sure, but typically the "lope" is affected by the LSA. The more narrow the LSA (111 vs 114 let's say) the more valve overlap, and that is essentially what is causing that sound. At high rpm in an NA engine, valve overlap is a good thing because it helps "cheat" things into happening faster. Now in a boosted application, you are already causing a rapid rise in cylinder pressure and with excess valve overlap you can actually force air out of an exhaust valve and loose power which is why you want a wider LSA in a boosted application. Cam profiles are all very application specific.
