[Z06] 2001-2004 C5 Corvette Halltech Venom II @ RPI Designs
Platinum Supporting Vendor
If you have a 2001-2004 Corvette C5 (Z06 included) and you are looking for an easy to install intake system the Halltech Venom II is just what you need. A no cutting, high gain intake system that allows you to install in 30 mins and go back to stock at any time without permanently modifying your Corvette. Designed from the same mold of the all new Killer Bee II Z06 Cold Air Induction Systems, this second generation C5 Corvette intake flows more air than any induction system on the market (10-15 rwhp gains). It utilizes the stock Mass Air Flow sensor for easy installation and seamless smooth response on the street or at the track. Starting with the Killer Bee II 15" wide Halltech Corvette C5 filter with a built in velocity stack flange, the actual changes to our Venom mold design have increased flow to your C5's throttle body significantly.
The filter can be cleaned with a simple K&N cleaning kit found at all automotive parts stores. We also include for free on all Z06 orders (not needed for regular C5's) our HC.125 Honeycomb Flow Straightener which will keep the Z06 cars from getting intermittent "lean codes".
Fitment: 2001,2002,2003,2004 C5 Corvette; Base, Coupe, Covertable and Z06
Item # 022-001
Website Link : https://www.rpidesigns.com/shop/item...tech-venom-ii/
Item # 022-001
__________________
