[Z06] 100 octane fuel / Good or Bad?
Originally Posted by MD Petite
Hey I have found a gas station that has 100 octane fuel. I have a '02-Z-06, I have ran it and it definatly is more snappy. But, I was recently told that it wil burn my plugs and could burn a hole in my pistons. Any truth to this? Please help!!!!!!!
Someone can correct me, but I believe you will find no real gains or benefits - except to the retailer!
For a bone stock LS6 of LS1 motor for that matter a minimum of 90 octane is suitable. Most manufacturers will say 91 to 93. Premium. Whatever you want to call it. 100 octane will not cause any damage to the motor and will probably give you an very, very small improvement in your gas mileage.
Other than that it just sounds good when you say it to someone who doesnt know.
I did have a problem in the summer with my '02 coupe pinging under hard acceleration with cheap gas, (Plus). I had the computer programmed and the variables could be modified, so I couldnt even say if the gas was the direct problem.
Now when you start getting into high compression motors the octane keeps the pre-detonation to a minimum and causes less motor damage.
Contrary to what many people believe, higher octane fuel does not have more energy. People have it all backwards thinking that higher octane fuel produce more power, when in reality it is a simple fact that the higher the compression a motor is, the higher the octane fuel it requires to resist detonation.
If you have a non computer controlled car running a given octane and you have knock, then running a higher octane fuel will indeed produce more power, because of the fact that the knock is eliminated, or if you run higher octane fuel, you can then manually advance and run the timing higher, therefore producing more power. If you are runnig a computer controlled car, and if it was tuned from the factory to run 100 octane fuel and you ran say 92 octane, then it would probably knock and therefore the knock sensors would send a signal to the ecm thus retarding the timing to eliminate knock and therefore reduce the horespower output of your motor. However, since our Z's are tuned for 91 octane, there is no way the aforementioned would hold true.
If one does not believe my statements, go run dyno tests, go run track time tests, give concrete data, but I guarantee the data would not substantiate the "assometer" claim.
Northeast for sure
Originally Posted by MarkT 2002
Where do you get 93 octane? If I recall premium is 91 octane in CA.
MarkT
MarkT
OK Thanks for the info. Sorry for such a dumb question
question!!!!!!!!
assuming that you don't change anything in the engine, you can also run lower quality fuel during cold weather and at higher altitudes w/o detonation. during the summer, my car ran like crap when I filled it up on base, so I started buying gas off base and everything cleared up, but when winter hit I started filling up on base again and haven't been any problems. In short, run the lowest octane that won't cause your engine to knock any more than that is a waste of money. the LS1/2/6 are good with anything above 91 octane.
incase anyone in Europe reads this, 98 octane here is the same as 93 in the states.
Get Some!
Not only will it not burn anything but the higher octane, slower burning fuel is actually a little cooler because it does burn slow. The old myth about higher octane burning things comes from the days when we left leaded gas behind, and people were burning valves.
I've been into the lower octane! at higher altitude
Please run some answer's on my Question (see my new thread 2002 Z06) this one will blow you away.
Sid
Sid
Like others posting in this thread have said; you typically will not gain any advantage by running higher than 93-octane on a stock engine.
Originally Posted by FRISKY
Higher octane fuel usually burns faster.
On the origional question.. If your car does not ping the higher octane does nothing for you.
Eric
St. Jude Donor '05
MarkT
MarkT
St. Jude Donor '05
MarkT
MarkT
Originally Posted by Mallory
No it doesn't... It burns slower... Ping is PRE-Detonation. So the fuel is burning too early. By extending the burn time, it will create pressure over a longer time instead of popping everything at once and being done.
“Burn rate” is how fast or slow the fuel will complete combustion once it has been ignited. Typically this process will be completed within 20-degrees of crankshaft rotation from TDC, and that is a very small amount of downward motion of the piston in the bore.
“Ignition rate” is how quickly the fuel can be ignited and is a product of octane. The higher the octane number, the more heat and pressure will need to be generated in the combustion chamber before the fuel can ignite.
Chemicals added to gasoline to increase the resistance to pre-ignition/spark knock/detonation also decrease the amount of BTUs available per pound of fuel. That is why you should use the lowest octane fuel possible that won’t cause the computer to pull timing or “pinging”.
Popular Hot Rodding Magazine, January 1998
By Scott Parkhurst
"The burn rate of a fuel is a measurement of the time required for complete combustion of the air/fuel mixture. The notion that octane ratings affect the burn rate of fuel is about 180-degrees from reality. Burn rate is a function of several variables, and the two are completely independent, although there is generally a correlation between higher octane ratings and faster burn rates.
To give you a good example of this, we contacted Jim Wurth from Sunoco Race Fuels. He explains, "A perfect example is Sunoco Maximal, which is our fastest burning fuel, and coincidentally one of Sunoco's highest octane fuels at 116 (R+M) / 2. A lot of Pro Stock teams rely on Maximal for those sub-seven second runs. When they are turning 9,000 rpm or more, the fuel has to burn pretty quickly to achieve complete combustion".
If you chose to try some of the 101-octane fuel, make sure it is unleaded. Using leaded racing fuel or Aviation gas will cause problems with your catalytic converters and oxygen sensors.
