Axle seal leak @1200 miles...anyone else?
About four decades ago three engineers at GM's Tech Center named Bob Dega, Jim Symons and Jack Brown did a lot of hard work advancing seal technology and improving the quality of seals (both radial shaft seals and mechanical face seals) provided to GM by their suppliers. Since that time things have obviously regressed markedly and the seals now purchased and used by GM are once again obviously inferior. Once your GM warrenty runs out you the owner will bear the very considerable costs of replacing all these failed water pumps, engine and drive line seals. Too bad GM is so penny wise and pound foolish when it comes to the seals they purchase.
mine leaks on the drivers side cover and my dads is in the shop right now getting his fixed his leaks at the trans and on the drivers side
it sure is nice after about 3 miles on the freeway there is oil on the entire back of the car good job gm
im gonna let mine dry out and blow up
Seals can go quickly throughout the drive train when a car isn't driven enough. Apparently even with new cars sitting unsold for too long according to your post. I would make the dealer fix every one as you find it.
C6 Rear axial seal leaks
I had to return THREE SEPARATE TIMES for this fix.. I noticed a few drops of gear-oil on my garage floor.. The first time they replaced the trans axial seal. But, the "small" leak continued.. Then it was another seal on an adjacent side? Last week I noticed the same leak on the floor, and I have to take it back again now.. Seals themselves are cheap/they just cost a couple bucks.. However, there are many designs: single-lip, double-lip. As well as many different materials.. The cost for the labor replacing them can be high, depending on what's involved. Plus, it's very easy to re-damage the seal (or bearing) by incorrectly installing it.. I myself (worked for a National distributor of many such bearing and seal Manufacturer's) and have seen hundreds of different seals (and bearings), and the reasons for their use. But I can't expect my Dealer to let me into his shop. All I want is the car fixed completely and correctly.
My left side axle seal started leaking after swapping to C5 axles. I changed the seal out. The leak continued. I changed the seal a second time. The leak still continued. I replaced the axle AND the seal for a third time and it still leaks. I've been extremely careful with the installations and it makes no difference.
Once I disturbed the factory installation...it simply will not seal correctly.
