quick question for a c6 OnStar user with NAV
When you use OnStar, I am pretty sure it mutes the radio. But, my question is, do you know what speaker(s) then play the OnStar communications? I'm curious as to whether it goes thru 1 or more of the 7 radio speakers, or whether there's a dedicated speaker just for the OnStar.
FYI -- I'm asking b/c I'm wonder if the OnStar audio is somehow coupled thru the NAV head unit or if it is fairly independent (other than muting the factory unit).
Thanks.
Thanks.
1 Post
i can't say for sure WHICH speakers of the audio system it comes through, but it definitely doesn't have it's own independant speaker(s). OnStar mutes the NAV radio's audio and then plays over the stereo system speakers.
whether it plays over just the fronts or all, i have no idea.
Thanks for the thoughts and I'd sure appreciate an update on which speakers.
However, let's not go overboard if Fred is going to hurt himself doing research. Also, Fred, my check to you for $0.75 is in the mail for your coffee, unless you do Starbucks as my wife enjoys, in which case I guess it's about eight bucks?
Thanks.
Thanks.
Originally Posted by shopdog
The OnStar audio is fed to the HU and goes out through the speakers same as any other audio source in the car.
I also was hoping that the Bose amplifier was muted at the same time as the radio, because I plan on connecting speaker signals from another unit to the amplifier mid-range outputs and I don't want those signals to any way damage the amplifier, which I was hoping would be muted when I used the OnStar mute input. Perhaps the output impedance of the amp can handle this even if not muted?
Thanks.
