Why 14.4 volts?
Originally Posted by jterp
Why does the battery read 14.4 volts? It's a regular 12V battery, right?
Originally Posted by shopdog
A fully charged battery measures 12.5 volts. But just after full charge is reached, battery voltage will be 13.8 volts. This extra voltage is called "surface charge" and even a small discharge will cause the battery to drop back to 12.5 volts. But to charge the battery, it is necessary for the charging voltage to be higher than the surface charge voltage. Thus normal running voltage in the car will be in the range of 14.2 to 14.4 volts.
each cell is over 2 volts like 2.6 per cell (I think) times 6 is about 13.2v on a 12 volt Batt. Alternators can charge up to 14.7 as old school tech goes but some cars may be different today.Alts regulation doesnt always go up to 14.7 only as needed.Amp ratings depend on the alt options.There are a few different amp alternators available.
Originally Posted by LS WON
What is the alternator capacity in AMPS?
