My iPod install
My iPod install
Since it seems the CD changer will never come, I did an Ipod.
Used the modified for Nav AAI-GM24 adapter and an iPod Nano in black.
Works great!
Take a look.
Works great!
Take a look.
Originally Posted by Rudy525
Perio,
Looks Great, did you install?
Is there a AUX input on back of OEM Bose HU?
Thanks,
Robert
Thanks,
Robert
Nice install!
Looking to install an plug n play sirius sportster, I was hoping for a AUX input. I didnt want to input through FM Modulator.
Great Looking Install!!
DO you know if that will also work with a 02 escalade?
Where did you pick it up from?
thanks for the help!!
They have all kinds of adapters.
St. Jude Donor '05-'06-'07
Works great!
Take a look.
Works great!
Take a look.
Great job and looks fantastic! I am considering doing the same. Can you post additonal installation instructions for us brave enough to follow your lead? Did you have to remove and of your console or did you cable from underneath?
All the wiring info comes with the AAI-GM24 from PAC.
If you have NAV, the harness needs to be modified.
Check out this link:
http://forums.corvetteforum.com/show...25&forum_id=74
The console and radio need to come out. It takes some time and patience but it is not tough.
Can you give detailed info on all the parts you needed? What did you using to connect the iPod to that adapter? I just saw RCA outputs on it.
I was trying to figure out if the C6 (2006) was prewired for a changer or not because the shop I asked said if it was they could work something out, otherwise they'd have to hardwire something which would cost more.
I don't have the NAV like you do, but can you tell me if the thing was prewired for an external changer?
Works great!
Take a look.
Works great!
Take a look.
I don't own an iPod at this time but I do use a small MP3 player. Perhaps this is the way to go. Thanks for the post.
Originally Posted by quickride
Your installation is very clean, good job. It appears that the mythical MP3 update for NAV radios that don't play MP3's is just that, a myth.
Works great!
Take a look.
Works great!
Take a look.
Originally Posted by rclark
What did you use to mount the nano? If it's custom made, could you post a pic? Thanks
Just velco. This way it is easily removed to take to a computer to change the songs/update it. Also the work is completely reversible with not damge to the car whatsoever.
