Should I start or not start my C6 during winter storage?
Received 3,103 Likes
Finalist 2020 C7 of the Year -- Unmodified
I heard it was bad to start your car during the winter months if you are not going to drive it . Is this true? I never start mine and just move it back and forth during the winter months so my tires wont have flat spots.
I would not start it, I don't think it will hurt it, but there is really no reason too start it. Use stabil in the gas, fill up your tank, get a battery tender, park on some carpet squares, get a good cover, and I would say you are set. Also sprinkle some moth ball under the car. Change your oil in the spring, (optional), and have fun.
I start my C6 once every week or so. If the weather doesn't allow me to drive it, I'll let it run for 45 minutes to an hour and move it back and forth in my garage. I've been doing this with all the sports cars I've ever owned over the years and have never had the slightest problem. It is important, however, to let it run for a while after it's reached its normal operating temperature.
Why can't you just take the car out once a month and drive it? This is all you need to do. Surely there will be at least one day once a month where there is no snow on the streets. Or do you live in serious snow country perhaps where the snow never leaves the street???
I really do not see ANY reason why a car cannot be driven throughout the winter, especially if you limit useage to just "nice" days. This would be the BEST way to take care of your car... period.
I would not start the engine, by starting and not driving it the engine oil will develop condensation. This will dry out when driving the car, but not when just sitting at an idle. This would do more harm than good. This is something I read some time ago, and it makes sense to me.
Even if you are going to take it out for an occasional drive you still should winterize the car if it could set for more than 3 or 4 weeks. Especially the battery tender and the stabil. I personally would not start it just to let it idle. I know the gentleman above has had good luck with it, but most experts will tell you not to do this.
Only on nice days may I add.
You don't live in North Canada do you?
[QUOTE=tiger33]My advise is Use it or Lose it. I even drove my motorcycles all winter.
I keep my insurance all year round. On my bikes there are a minimum of two or three days a month to ride. On the vert it will go out on any nice day. Point is you never know when those days will pop up so I'm always ready when they do.
If you start the car up, you should run it long enough for the oil to reach normal operating temperature and stay there for 10 minutes. This is enough time that you might as well drive it down to the local store and put some gas in it and pick up a few brews for later consumption.
Otherwise, leave it sit.
St. Jude Donor '03-'05-'06-'07
I wouldn't start it. At idle the fluids are not sufficiently circulated throughout
the engine. And this does nothing for the tranny, the portion next to the
engine warms up a little but no benefit is gained.
No, let her set or take her out for a 15 to 20 mile drive when weather permits.
More fun than idling anyway!!
St. Jude Donor '06
St. Jude Donor '06
My plans are not to start the Vette until I can drive it for at least 30 minutes. You want to both get the oil up to operating temp and give it some time to boil off any moisture in the oil. Just starting the car and letting it idle will cause moisture from the combustion that will not burn off and can cause internal corrosion.
Location: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
1 Post
St. Jude Donor '06-'07
I usually don't start them unless I need to move them around the garage.
I don't do it....I see no benefit at imposing cold start to the engine and building up condensation. Raise your tire pressure at 40PSi and forget about the flat spot.
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
