Burning MP3s for the NAV - tricks and tips
#41
Sounds like some more experimenting is in order - which is fine - I have had 11 days off and has been snowing in MN - no real errands to do and I don't feel like doing WORK WORK ... or much of anything else ...
#42
#43
Okay, 15 minutes till we leave for dinner - AND I HAVE FOLDERS! They are not the same as the folders I set up in Windows (I wish they were). They are as you say - by album.
What I did was clear my library, and re-import the files again. I did have the "Organize folders...." checked. I think just re importing the files probably is what did it.
Thanks again for all the help!
#45
Some additional tips
This forum is great....
My 2005 C6 seems like a new car with these updates.
Here are a couple of possible things to check when using iTunes:
On the top toolbar click on:
Edit, Preferences,
Advanced tab…
General sub-tab
Check Keep iTunes Music folder organized
Importing sub-tab
Import Using: MP3 Encoder
UN-check Create file names with track number
un-checking this allows 22 characters in the file name...does not add the track number
Burning sub-tab
Check MP3 CD
There are other options in the Advanced tab area, but they didn't seem to change how it was displayed in the car. The above options did effect how the folders, artist, song name, etc were displayed.
Also, once the playlist is created...highlight all the songs and right mouse click and convert the tags.... I tried 1.0 version and artist did not always show...tried 1.1 version and all titles, artist, folders, etc now all show.
Convert ID3 tags
ID tag version 1.1
Critical key points others have mentioned....keep titles, etc to 22 characters or less.... that tip really helped me. Also, sort by Album.
Happy New Year to y'all
Allen
Edit, Preferences,
Advanced tab…
General sub-tab
Importing sub-tab
Burning sub-tab
Check MP3 CD
Convert ID3 tags
ID tag version 1.1
Allen
#46
Originally Posted by abrimberry
Using MusicMatch and Nero
Only 8 characters appear regardless if having 1 or multiple
Anyone use MusicMatch or Nero to successfully create a CD that shows the "Track List" correctly? Thanks.
#47
Night Race Blue 427
Location: Muncie, Indiana ...... Can I buy an amplifier on time ... I ani't got no money now but I'll pay you before I die
Has anyone figure out if there's a way to create subfolder and burn them to a disc with iTunes? Like having folders for artists with subfolders for their albums in them.
#48
Crabman and harley-vet - you guys must not have gotten any sleep last night judging from the times of your postings ...
#49
Then I use Nero Burn to put the music to cd. Just select the main folder, in this case "White" and the two subfolders will be there on your nav. You can make as many subfolders as you like from what I can tell. Load the disc up with other albums or different artists and subfolders.
When you play it back in your C6, you'll see the "Additional tracks" button. Push that and you'll see your folders. Select a folder and in this case you'll see the "Disc 1, Disc 2 subfolders. Select the one you want and it will play it in running order.
The draw back to this method is the player will not list the song, artist album as depicted on the player. Mine lists the song and artist in the same line. But it will play the album in it's original running order as if it were the real cd.
I have tried itunes and gone through a stack of disc's experimenting. I have had little success. But with Music Match and Nero burn it works every time in the order I want to hear it.
I hope this helps?
SB
Edit: Another option if you want to listen to songs in no particular order is to drop them into one folder (just the songs) and burn it as one large album. I did this with the two Garth Brooks box sets. I put all 140 songs into one folder, burned it to cd. Then in the car I select "random" and they play in a random order for as long as I can stand it! I have the Time/Life Guitar Rock series. I plan on using this method to make that cd. It's pretty cool because I can eliminate the songs I don't care for before they even get on my cd. Just another way of doing it. I use Music Match for this method and Nero for the folder/subfolder style.
#50
Night Race Blue 427
Originally Posted by Braced
I have tried and tried using the itune way with little success. I have how ever made several MP3 disc's with many subfolders. I start by ripping the cd using Music Match Jukebox program. Make sure you go into edit and check the order you want the files tagged in. Ie. song order first followed by song name followed by artist, followed by album name. Tagging is very important. Once tagged, that's the order the player will read it. Then you can go into My Music files using Windows explorer and rename the folders to anything you like (but the actual songs are already tagged). You can move them into sub folders if you like. This works great for double album/cd's. Ie the White Album from the Beatles. As an example name an empty folder "White" then move the two folders (disc 1, disc 2) into that folder. Remember, only 8 letters will be read by the C6 nav unit.
I hope this helps?
SB
I hope this helps?
SB
#51
I already konw how to burn discs with subfolders using Musicmach. That's not what I asked.
Maybe someone else will benefit from it. Have a nice day And Happy New Year to you too.
#52
Play Nice in the sand box
#53
Moderator
Fantastic thread - thanks so much to you all for the advice!
Question - do the folder names need to be 8 characters or less or 22 characters or less?
#54
Night Race Blue 427
#55
This is all great stuff...thanks to all who've helped us resolve the MP3 issues.
Here's another one: Has anyone here figured out a way to burn MP3s without gaps between the tracks? I'm specifically refering to making MP3s of CDs whose tracks run together with no audible breaks between them (e.g. "Side B" of Abbey Road, most of the early Moody Blues, etc.). When I make MP3s of this material, the software automatically inserts breaks between the tracks whether or not they're there on the originals. I guess what I'm looking for is a way to do "disc at once" rather than each track individually.
#56
2015 C7 of Year Finalist
Edit, Preferences,
Advanced tab…
General sub-tab
Edit, Preferences,
Advanced tab…
General sub-tab
Importing sub-tab
Burning sub-tab
Check MP3 CD
Check MP3 CD
Convert ID3 tags
ID tag version 1.1
ID tag version 1.1
Of course, I am more interested in making a decent disc for the car, so I can handle replacing the artwork after I have finished.
With the options modified as above the disks are reading with folders for artists, then folders for each album with the tracks therein.
#57
Does anyone know how to create the folders in a Data CD with Windows Media Player 10? I have created the data CD (required for MP3 files) with 3 playlists, but the folders do not show on the car CD player. Also, what controls the order of the songs within the folders?
#58
Doubt this is do-able ....
#59
1 Post
St. Jude Donor '06-'07-'08
I hope this helps?
SB
I hope this helps?
SB
Thanks. With this new mp3 "toy" in my vette, I have learned that I don't know too much about making the mp3 discs, but I have managed to get a couple of decent ones. I thought I had it down, but I am learning to get the info displayed properly. Thanks for all the information.
Jim
#60
YEP>>>>what a better way to spend a New Year coming....In the Vette with my lovely wife. We were driving around town listening to the MP3's ...night was perfect. Just got back into the house and had to share that I got the MP3 thing to work every time.
