HELP Need To Find Factory Firewall Grommet
Old 02-20-2006, 08:17 PM
NotSpdn
NotSpdn's Avatar
Default HELP Need To Find Factory Firewall Grommet
I am installing some electronics, and I need to find a factory firewall grommet/hole. It only has to be large enough to accomidate a plug the size of a telephone jack. I also need to find the same in the rear, or route the wire up to the firewall hole. I would also like to know the normal wire routing used along the chassis. I have to route two small wire cables from the grill area to the dash, and two of the same from the rear area to the dash. I would like to keep it looking factory installed, and I would rather not drill any holes, if I do not have to drill them.
Old 02-21-2006, 09:35 PM
Norske
Norske's Avatar
I haven't run my wires yet, but here are some ideas for you:
Previous Discussion Threads:
http://forums.corvetteforum.com/show....php?t=1151044
http://forums.corvetteforum.com/show....php?t=1064199
http://forums.corvetteforum.com/show....php?t=1056714
These is a large pass-through just behind the battery on the passenger side, be careful not to damage any of the harnesses or you'll be in a world of trouble.... Just follow the main harness from the fusebox that comes out in the engine compartment under the battery. You will find a bundle of wires in the passenger's footwell, behind the top edge of the carpet.
Quick Reply: HELP Need To Find Factory Firewall Grommet
