Wheel offset and pattern same as C5
Is the wheel offset and lug pattern for the C6 the same as the C5's. Basically I want to know if C5 wheels would fit on a C6, and vice versa.
from a c5 on a c6 it will work, I see guys running them in autox.
Front and rear offset on C5 is the same (58mm?), on the C6 it's 56mm front and 79mm rear. Bolt pattern is the same. C5 Z06 used different wheels than the other C5's.
Originally Posted by blkc6z51
The lug pattern is the same, but the offset is not, you can run the 18s
