Oil Consumption
Oil Consumption - New Bulletin
I have been closely following posts regarding oil consumption. I have the same issue. We went thru the oil consumption test. (Over 1 quart in 1,000 miles, Black soot on the rear of the car and the exhaust tips) My Chevy service manager said he talked to Kentucky. There is a new service bulletin coming to replace lower rings in all 8 cylinders. Something about using iron rings on the lower groove. It scares me to have them go thru the engine, and he thinks they can do it with the motor in the car.
Hey, at least he is willing to do something about it!
Any knowledgeable information out there?
Vin
Vin
Vin
Vin
I suggest you do an advanced search for threads started by S2K.
He's been fighting with the dealer about an oil burning problem for months. Recently, he had a breakthrough...the dealer determined from a leakdown test that it probably was burning oil. They re-ringed two cylinders, but the outcome is still uncertain. It seems that it's hard to tell how much oil is being burned if they don't know how much to put in.
S2K will definitely be interested in this new service bulletin.
I'm burning about 1 1/2 to 2 quarts per 2000. I went round and round with GM a while back. But gave up after I ran out of options, besides legal action. There are a number of other forum members with the same problem. If you post the info on the service bulletin it would be helpful. Thanks
An engine at WOT and high RPM has the potential to pull oil over through the fresh air vent system. The PCV system goes into reversion. A common addition to overcome this event is to add a small catch jar in the the fresh air pcv line. Additional volume can slow air flow and also catch oil prior to injestion through the throtle body.
Nothing new here. At WOT and high rpm the rings flutter and blow by escalates thus inducing reversion. All engines experience this, some worse than others. Manuals tend to travel up into red line range more frequently.
Inline catch jars a readily found at your local speed shops.
1 Post
GM runs these engines "loose". So some oil consumption is normal. A "loose" engine will produce more power, less friction. Oil consumption goes up with high rpms too..
Some oil also passed thru the PCV system.
I would rather add a quart or two between changes than to have the dealer try to fix it.
The LS1/LS6 engines also consume oil when driven hard. The lower land ring was revised in 2001 to better control oil consumption.. it helped.. but its just the nature of the beast... there are worse alternatives than having to add some oil every now and then...
Oil consumption issue
Some oil consumption problems can be directly related to break in thechnique. Plus, if I'm not mistaken, the C6 comes with synthetic oil from the factory. The most important factor in early oil consumption is the incomplete seating of the piston rings. This NEEDS to be acomplished in the first 50-100 miles.Syntheic oil hampers this due to the lack of engine wear. Engine wear is actually a good thing for the first 1000 miles. A gentle gradual break in is not condusive to piston ring seating, ESPECIALLY with synthetic oil in the crankcase! Check out Motoman at http://www.mototuneusa.com/break_in_secrets.htm BTW, Porsche and Audi consider the consumption of 1 qt/1000 miles to be "within acceptable limits".Oil is cheap!
My Chevy service manager said he talked to Kentucky. There is a new service bulletin coming to replace lower rings in all 8 cylinders.:
Where is that video with the guy that rammed into the dealership with his new SUV. I would want to study that so I can do it right.
John
Originally Posted by JohnDS
Good GOD! This would require a complete engine tear down. There is no way I would put up with that crap.
John
John
My 112,000 mile GMC doen't use 1/2 that much oil, my wifes 98,000 mile uses less and my 58,000 mile C4 Corvette uses about 1/10 qt in 6,000 miles.
