Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
- How to Install Front License Plate Bracket
Step by step instructions for do-it-yourselfers.
C6 Front License Plate Bracket
#1581
Received 2,826 Likes
2021 C6 of the Year Finalist - Modified
I got my order promptly and installed it and was surprised how well I liked the look of it on the car.....I was fanatical about messing with the front end of my Grand Sport but don't mind having the plate on there. Good stuff, Thanks...........
#1582
Thank you for posting Marcus
#1583
I was just about ready to pull the trigger on a bracket for my 427 until I read this post. I am not so sure buying something that has to be modified to keep it from destroying the paint is such a great idea. Is this typical for the TFR brackets for the 427? I don't even want a front plate and may take my chances on a ticket first.....
How is it now that you have had it a while?
#1585
#1586
No screws??
In Stock!
The Top Flight Reproductions C6 front license plate bracket is the best looking mount available and it's legal in all the two plate states unlike some of the other after market front plate solutions. It follows the contour of the front bumper. Installs easily without lifting the car. Requires no drilling for attachment like some others do. Our bracket is priced considerably lower than other after market solutions and is made in the USA .
All three Top Flight Reproductions front license plate brackets are in stock and ready to ship. Visit our website at www.topflightrepro.com or call 781-279-1279 and ask for Ray.
C6 Grand Sport/Z06/ZR1 Removable Front License Plate Mounting Bracket
C6 Removable Front License Plate Mounting Bracket
C6 Permanent Front License Plate Mounting Bracket
#1589
removable bracket for base C6
On the removable bracket for the base C6, does the bottom edge of the bracket contact the bumper below the grill, or is there a small gap between the bracket & the bumper?
#1590
I just wanted to let you know that we are a very satisfied customer. We used your front plate kit on our '08 coupe and were so satisfied that I installed it on our 427 convertible the day I brought it home from the dealer. It is the only front license plate mount that actually looks like it was designed to compliment the front of a C6 Corvette.
Thanks for a great product.
#1591
We install a foam strip on the back side of the bracket and there is typically and 1/8 of an inch gap between the bumper and the foam strip
#1592
#1593
Can not wait
Ordered the bracket and 2 black frames today. Cannot wait for them to get here. Did not know what I was going to do about front plate till I found this. It look great in the pictures.
#1594
I, along with several others, have had problems with the adhesive coming loose. See https://www.corvetteforum.com/forums...e-bracket.html
Looks great, but I have this problem that needs correction.
#1595
#1596
I am considering buying two of these after a recent incident with the local LEO. My in-laws would need a supersonic blue, and I would need a carbon flash metallic. Does anyone have pictures installed on these colors?
#1597
In Stock!
#1599
I would want the removable system for my C6 Grand Sport. However, I'm not clear as to what it would look like without the plate attached? Do I still have the bracket showing or what hardware is transparent?
Thanks!
Thanks!
#1600
You would remove the license plate bracket via 2 wing nuts, the only thing that stay attached to the car is a flat plate and two threaded studs, which would not be visible if you were standing in front of the car
