C6 Dash discoloration
During the process of installing an aftermarket decal on the passenger side airbag, the dash became discolored (ie. streaked where cleaner ran down). I cleaned the dash with mineral spirits and alchol per the instructions. Now what do I do???? Help!
Never had this problem on the C5. Is the C6 material different?
Greetings
I believe the dash and door panels are coated with a semi gloss to reduce the shine. You will probably need to replace the dash panel.
regards
For future reference, the expert who repaired a gash in my dash said I should just use a rag dampened with water to clean my dash. Then dry it.
Try a solution of half white vinegar & half water to clean the discoloration. Try it first in the most inconspicuous spot that is stained.
Originally Posted by jharshaw
Pretty brave using mineral spirits!
http://www.shellchemicals.com/white_...98,676,00.html
Does that mean you should never put any dressing on the dash and doors - such as Armor All or other products?
Thanks for the info.
Instrument Panel
Use only mild soap and water to clean the top surfaces
of the instrument panel. Sprays containing silicones
or waxes may cause annoying reflections in the
windshield and even make it difficult to see through the
windshield under certain conditions.
Interior Plastic Components
Use only a mild soap and water solution on a soft cloth
or sponge. Commercial cleaners may affect the
surface finish.
surface finish.
surface finish.
Originally Posted by Wayne88
Why should the interior plastic on the C6s be any different [more delicate] than any other car in the world ???
