Door touching fender - door sagging
check yours.... the gaps looked OK.... i was reading someone elses post and decided to check mine.... glad i did before it got real bad!!!!
this is the passenger door..... it was hitting two places...
i had to move the door in a little and away from the front fender....
this is how much i had to move the drivers side to pick it up to be centered in the latch....
i moved only the upper hinge....
