Penalties for Non-Premium Gas
With high gas prices, there have been lots of octane questions lately. Yes, you can use regular or mid grade without grave risk to your engine, but…… This post summarizes the “buts”. For those who haven’t seen my posts, I’m an oil company engineer with one of the majors, but I keep my brand out of it. The Forum is a good place to share knowledge, so I’m simply trying to share where I know the facts.
First, understand how your engine compensates. There is a knock sensor which detects when your engine starts knocking. It can eliminate knock by retarding the spark. So when you use regular or mid grade, your engine knocks momentarily, the sensor senses the knock, and it eliminates the knock by retarding the spark, probably before you even notice that it’s knocking. Do not kid yourself into thinking nothing has happened. Trust me on this. If you are running regular or mid grade, your spark is running retarded.
So what, you ask? There are three effects. First, you have slightly less power. It is not a huge drop, and the Vette has so much power, you probably won’t feel the loss in the seat of your pants. But if you measured acceleration time with a stopwatch, you will have lost a few tenths of a second in 0-60 time. Second, your gas mileage will be slightly poorer. This will be even more difficult to see than the acceleration time because so many thing affect mileage. But if you ran an average over many tankfulls, you’d lose half a mile to a mile per gallon. Third, you will frequently have mini-knock episodes that you probably won’t even notice. That’s because the engine computer assumes you will normally run premium, so it keeps trying to run the spark advance back to normal, then encounters knock, and has to retard it again. This is not a serious engine damage risk because the computer is so quick at detecting and correcting. But it is some slight risk. Do the sum of these three issues equate to 30 cents per gallon? That’s for you to decide. The important thing is that you know the facts, and don’t go around telling people that you use regular and there’s no difference. Huge difference? No. Difference? Yes. 30 cents per gallon worth of difference? Your decision, not mine.
Incidentally, while there is a performance penalty for octane below 91, there is no benefit of octane over 91. That’s because there’s an optimum spark advance. Performance is degraded in either direction from optimum, both in the less and in the more directions. The Vette is designed for 91, which means that it can get to optimum advance at that octane. Once there, it does not keep advancing the spark, because that would actually lose performance. Thus, octane over 91 is wasted. Slight fib there. As an engine ages, deposits very slightly increase the required octane to avoid knock, perhaps by a number at very high mileage. But other than that, the only circumstances where greater than 91 octane would be of benefit would be if you modified your engine, such as raising its compression ratio or adding a supercharger. So all you California people who complain about not being able to buy 93 octane shouldn’t worry.
Unless you track your car, the only penalty would be a slight loss of HP/TQ if the knock sensors detect any pre-detonation and then pulls some timing out.
In everyday driving you'll never miss the 10 or so HP lost. But I'm sure you'll get the usual responses wondering how you can afford a $50K car and can't find a few extra dollars to feed it the best fuel.
Bottom line, you won't harm the car.
Tom
Tom
LDB -
Thanks for the great post. You're one of the reasons why this forum rocks!
I've been one of those that have been feeding my Vette 93 octane, because it is readily available. Next fill-up I'm going with 91 octane and save a few bucks.
Thanks for the great post!...After reading it, I plan to continue feeding the Vette what it was designed for.
A couple of questions I have, maybe you can respond.
First, what efeects does ethanol have on our engines?
Second, does it matter where you buy your gas? I use BJ's Wholesale Club because of membership discounts per gallon, but is it OK to use versus the majors?
Thanks in advance!
Thanks in advance!
Assuming that the knock sensors and ignition retard can completely eliminate engine damaging spark knock is not true.
You can get away with a little less octane than desirable, and the computer will compensate. But put 87 in an 11 to 1 CR motor like the LS7 and it will rattle to death. The reason is some spark knock has nothing to do with timing, it's the mixture self igniting (preignition) and the flame front hammers the top of the piston. The owner's manual cautions that engine damage can occur from severe spark knock.
I've heard it tons of times in plenty of engines, all with knock sensors. Every pickup I've owned with a 5.3L V-8 will spark knock like crazy if I don't blow the carbon out once in a while. I tried a K & N filter in my 04 Z LS6 once. The motor had ran flawlessly on 93, until the K & N and the first time I went wide open. It sounded like shaking marbles in a tin can, and a big puff of dark soot out the back. Just that filter making it a hair leaner put the engine into severe spark knock.
87 is for lawn mowers and grocery getters. In the vette, buy the best.
Originally Posted by antoniopaolo
Excellent information and much appreciated. thanks.
antoniopaolo
antoniopaolo
I don't know if she'll understand it all (any), but thanks for what I feel to be is a thorough, but not verbose explanation of the subject!
I generally only use Amoco Ultimate 93 or Mobil 93 in my performance cars for this reason but would consider 91 to save a few bucks, though they're actually all virtually the same price in my area anyway LOL.
The octane mix is added as the trucker fills up the gas station reservoirs, right? so how do we know for sure that the truck driver did his job.
If you fill up and put in 15 gallons you are talking about a whole $1.50. I'm not bragging but I can afford the $1.50 to keep the Vette running the way God intended her to run.
no doubt, it's like people who drive across town because gas is .05 cheaper, but they don't calculate the fact that they burn a gallon going to and from, thus negating their savings
