Old 03-06-2015, 05:23 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: General How-Tos
Print Wikipost
List of Service Bulletin Titles, and Recalls from NHTSA
Old 08-17-2006, 11:42 PM
TrackNoob
TrackNoob's Avatar
Default List of Service Bulletin Titles, and Recalls from NHTSA
Caution, long -- following is a list of Service Bulletins that apply to 2005 Chevrolet Corvette Coupe, and also recall info:
I am posting this information because I wanted the number for the bulletin on IPC (instrument panel cluster) grounding issue, and had some trouble finding it. So I figure this might be a handy reference for others, too. Note that for SBs it is JUST the number and title, not the actual SB body.
Bulletin Number: 009072004
TRANSMISSION SHIFT INTO REVERSE PRIOR TO SHUTTING OFF THE VEHICLE. *EH
Bulletin Number: 020730024A
DIAGNOSIS OF CRACKED OR BROKEN TRANSMISSION CASE. *TT 2006 AND PRIOR CARS AND LIGHT DUTY TRUCKS. *TT
Bulletin Number: 030730007A
ENGAGEMENT TIME OF ELECTRONICALLY CONTROLLED TRANSMISSIONS IN GENERAL MOTORS VEHICLES. VARIOUS MODELS INCLUDING 2000-2006 ALL LIGHT DUTY TRUCKS. *TT
Bulletin Number: 030844005B
POOR RADIO RECEPTION OR RADIO STATIC/ INCREASED INTERFERENCE WITH REAR WINDOW DEFOGGER ON OR SOME REAR WINDOW DEFOGGER GRIDS MAY BE INOPERATIVE. *TT
Bulletin Number: 030851001
TRANSSEAL TEMPORARY PROTECTIVE COATING REMOVAL INSTRUCTIONS. *TT BULLETIN 03-08-51-001, DATED 09/01/2003 REPLACED. *TT
Bulletin Number: 040089041
PRE-DELIVERY AND SERVICE GUIDE. *TT
Bulletin Number: 040601025
EXCHANGE PROGRAM FOR 2005 MODEL YEAR ENGINES. *TT UPDATE. *TT
Bulletin Number: 040729003A
MISMACHINED TRANSMISSION COUNTERSHAFT SNAP RING GROOVE. *TT UPDATED *EH
Bulletin Number: 040844023
VARIOUS RADIO/CD PLAYER CONCERNS. *TT
Bulletin Number: 040850018
DRIVER OR PASSENGER SEAT FUNCTIONS INOPERATIVE, BLOWN SEAT FUNCTION FUSE. *TT
Bulletin Number: 04086
REAR BRAKE LINE ROUTING. PRODUCT SAFETY RECALL. *TT
ONE OR BOTH REAR BRAKE LINES CAN COME IN CONTACT WITH LEFT EXHAUST MANIFOLD AND PIPE. *EH
Bulletin Number: 050308004
REVISED FRONT AND REAR UPPER AND LOWER BALL JOINT STUD NUT TIGHTENING SPECIFICATIONS. *TT
Bulletin Number: 050310004
TIRE PRESSURE MONITORING (TPM) SYSTEM - TIRE MOUNTING AND DISMOUNTING. *TT
Bulletin Number: 050310015
TIRE ROTATION ON VEHICLES WITH DIFFERENT FRONT AND REAR TIRE/WHEEL SIZES. *TT
Bulletin Number: 050310019
INFORMATION ON RUN FLAT, ZERO PRESSURE OR EXTENDED MOBILITY TIRES (EMT) AND UNIQUE SERVICING TECHNIQUES. *TT
Bulletin Number: 050495001
REAR WHEEL DRIVE SHAFT NUT TORQUE SPECIFICATION REQUIREMENTS AND INFORMATION ON REPLACEMENT SHAFTS FOR SERVICE. *AK
Bulletin Number: 050523007
INFORMATION ON VISUAL BRAKE ROTOR SURFACE CRACKING. *SC
Bulletin Number: 050601001
CHECK GAGES LIGHT BATTERY VOLTAGE, LOW ACCESSORY DRIVE BELT SLIPPING OR MISSING. *EH
Bulletin Number: 050603005
REVISED BATTERY NEGATIVE CABLE DISCONNECT/CONNECT PROCEDURE. *TT
Bulletin Number: 050604041
ERRATIC FUEL GAUGE READINGS, FUEL GAUGE READS EMPTY WHEN THERE IS FUEL IN TANK, DIAGNOSTIC TROUBLE CODE P0463 SET, SERVICE FUEL SYSTEM MESSAGE DISPLAYED. *TT
Bulletin Number: 050731001
CLUTCH PEDAL DOES NOT RETURN TO UP POSITION DURING SHIFTS AT HIGH ENGINE RPMS. *TT
Bulletin Number: 0508110001
AVAILABILITY OF FLOOR MAT/REAR COMPARTMENT DIVIDER RETAINERS. *TT
Bulletin Number: 050842004
INFORMATION ON APPARENT HAZE/SHADOW APPEARANCE OF HEADLAMP ASSEMBLY. *TT
Bulletin Number: 050842007
HEADLAMP ASSEMBLY SEAL TORN OR CUT. *TT
Bulletin Number: 050842015
HEADLAMP BALLAST PART CHANGE. *TT
Bulletin Number: 050859003
CREAK OR POPPING NOISE FROM ROOF NEAR WINDSHIELD/A PILLAR. *TT
Bulletin Number: 050866002
INFORMATION ON THE OPERATION OF THE REAR COMPARTMENT LID/HATCH/TRUNK EXTERIOR RELEASE SWITCH. *TT
Bulletin Number: 050868001
MALFUNCTION INDICATOR LAMP (MIL), DIAGNOSTIC TROUBLE CODE (DTC) P0833, CRUISE CONTROL INOPERATIVE. *TT
Bulletin Number: 050940003
PASSENGER SEAT BELT BUCKLE HARD TO MOVE PAST STITCHING AND/OR FINISH KNOT IS FRAYING. *TT
Bulletin Number: 060235002
DIAGNOSTIC TROUBLE CODE (DTC) C0710 STEERING WHEEL POSITION SENSOR (SWPS) SIGNAL, SERVICE STABILITY SYSTEM MESSAGE ON DRIVER INFORMATION CENTER (DIC). *TT
Bulletin Number: 07062004
CORVETTE NEW PRODUCT VIDEO. *EH
Bulletin Number: 0804
OIL LIFE SYSTEM RESET PROCEDURES - CARS. *NM
CORVETTE KEYLESS IGNITION. *NM
Bulletin Number: 08182004
ACTION CENTER TO IDENTIFY AND RESOLVE ANY NEW PRODUCT CONCERNS. *TT
Bulletin Number: 3060
THE ENGINE DOES NOT STALL WHEN PERFORMING A P1870 DIAGNOSTIC TEST WITH THE TECH 2 SCAN TOOL OR WHEN COMMANDING THE TORQUE CONVERTER CLUTCH ENABLE SOLENOID ON APPLICATIONS THAT DO NOT HAVE THE P1870 DIAGNOSTIC TEST LISTED. 4L60E OR 4L65E TR
Bulletin Number: 3079
STARTS WITHOUT BRAKE INPUT AND HARD TO SHIFT OUT PARK DIAGNOSTIC TROUBLE CODE 0161. *SC
Bulletin Number: 3104A
6-SPEED SHIFTER RATTLE GROWL BUZZ NOISE. *SC
Bulletin Number: 3109
LOW RESONANCE VIBRATION AT IDLE WHEN TURNING. *SC
Bulletin Number: 3126
MA5 5 SPEED NORMAL REVERSE GEAR OPERATION. *TC UPDATE. *TT
Bulletin Number: 3132
LOWER REAR SHOCK ATTACHING BOLT MAY BREAK AFTER TORQUED. *TT
Bulletin Number: 3134
NO CRANK AND DIC DISPLAYS NO FOB DETECTED. *TC UPDATE. *TT
VARIOUS ELECTRICAL PROBLEMS WITH A CELL PHONE CHARGER PLUGGED IN. *TT
Bulletin Number: 3139
LOW OR DEAD BATTERY. *TC
Bulletin Number: 3141
RADIO PROGRAMMING WITH BASE RADIO (US8). *TC
Bulletin Number: 3144
SLIGHT PULL LEFT OR RIGHT, TIRE WANDER. *TC
Bulletin Number: 3146
ABS BRAKE EBCM PROGRAMMING. *TC
Bulletin Number: 3155
ERRATIC OR INOPERATIVE OIL PRESSURE GAUGE. *TT
Bulletin Number: 3170E
IPC, INTERIOR LIGHTS AND/OR HEADLAMPS FLICKER. *AK
Bulletin Number: 3173
WATER LEAK ON DRIVERS FLOOR. *EH
Bulletin Number: 3199
INFORMATION ON LOW COOLANT MESSAGE. *TT
Bulletin Number: 3219
UNABLE TO PROGRAM TRANSMISSION CONTROL MODULE AFTER REPLACEMENT. *EH
Bulletin Number: 3225
PROGRAMMING PROCEDURE FOR THE REMOTE CONTROL DOOR LOCK RECEIVER. *EH
Bulletin Number: 3235
ENGINEERING INVESTIGATION ON THE NEW TRANSMISSION CONTROL MODULE. *EH
Bulletin Number: 3242
OIL LEAK AT OIL COOLER LINES. *EH
Bulletin Number: 3293
MULTIPLE ELECTRICAL CONCERNS AND INSTRUMENT PANEL CLUSTER (IPC) GAUGES INOPERATIVE. *TT
Bulletin Number: 3294
UNABLE TO PROGRAM A SPS MODULE. *TT
Bulletin Number: 3319
A SIR LAMP AFTER DEPRESSING THE HORN FOR MORE THAN 5 SECONDS OR USING THE HORN TWO OR THREE TIMES IN SUCCESSION. A CURRENT OR HISTORY CODE B0104 OR B0101 MAY BE SET IN THE SDM. *TT
Bulletin Number: 3320
4L65E (RPO M32) TRANSMISSION ACCUMULATOR SPRING USAGE. *TT
Bulletin Number: 3335A
INVESTIGATION OF PUMP AREA LEAKS. *TT
Bulletin Number: 3336
INDEXING DOOR GLASS THAT APPEARS TO BE STUCK OR INOPERATIVE. *SC
Bulletin Number: 3359
Bulletin Number: 3363
4L60E/4L65E NO REVERSE. *TT
Bulletin Number: 3369
TO BETTER UNDERSTAND SPRAG DAMAGE AN ENGINEERING INVESTIGATION IS BEING CONDUCTED. TYPICAL SYMPTOMS INCLUDE NO FORWARD MOVEMENT IN D4 OR D3 SHIFT LEVER POSITION. MOVEMENT CAN BE OBTAINED IN D2, D1 OR REVERSE. *TT
Bulletin Number: 3384A
CRUISE CONTROL, FOG LAMPS, ACTIVE HANDLING, RKE PANIC MODE INOPERATIVE. *TT
Bulletin Number: 3391
4L60E/4L65E AUTOMATIC TRANSMISSION MAY EXPERIENCE A CONDITION OF DISTRESSED TRANSMISSION FLUID AND/OR SLIPPING, LATE OR MISSED SHIFTS IN 2ND, 3RD, AND 4TH. *TT
Bulletin Number: 3397
TELESCOPING STEERING WHEEL INOPERATIVE. *TT
Bulletin Number: 3430
ANTI-LOCK BRAKING SYSTEM (ABS) LAMP ON WITH A DIAGNOSTIC TROUBLE CODE (DTC) C0820 SET IN THE ELECTRONIC BRAKE CONTROL MODULE (EBCM). *TT
Bulletin Number: 3439
SIR LAMP ON WITH A DIAGNOSTIC TROUBLE CODE (DTC) B1001 SET IN THE SDM. *TT
NO DRIVE IN D4 OR D3. TO INCLUDE 2005 GMC JIMMY. *TT
Bulletin Number: 3440
SEAT BELTS LOCK INTERMITTENTLY. *TT
Bulletin Number: 3441
FLOOR MAT REAR COMPARTMENT DIVIDER RETAINERS. *EH
Bulletin Number: 3442
TRANSMISSION FLUID LEAK FROM WEEP HOLE AT THE REAR OF THE TRANSMISSION. *TT
Bulletin Number: 3451
SLIP CONDITION IN 2ND 3RD OR 4TH DAMAGED 2-4 BAND 3-4 CLUTCH. 2005 ALL FULL-SIZED TRUCKS AND UTILITIES/2005 ALL MID-SIZED TRUCKS AND UTILITIES *SC
Bulletin Number: 3474
ERRATIC FUEL GAUGE - SERVICE VME. *TT
Bulletin Number: 3489
NO CRANK, TRANSMISSION RANGE INDICATOR INOPERATIVE. *SC
Bulletin Number: 3513
INTERMITTENT BLOCK OUT OF FIRST GEAR FROM A STOP. *TT
Bulletin Number: 3537A
DRIVERS INFORMATION CENTER SWITCHES INOPERATIVE. *TT
Bulletin Number: 3540
SERVICE VME - FRONT TURN SIGNAL BULB INOPERATIVE AT TIMES. *TT
Bulletin Number: 3551
SERVICE VME - FUEL GAUGE ERRATIC OR DEFAULTS TO EMPTY. *TT
Bulletin Number: 3559
REAR AXLE CHATTER SHUDDER ON TURNS. *SC
Bulletin Number: 3567
SPEED SENSITIVE WIPERS INOPERATIVE. *SC
Bulletin Number: 3588
SEVERAL RIGHT FRONT SEAT BELT ASSEMBLIES HAVE BEEN RETURNED THROUGH THE 100% LAUNCH PART RETURN PROCESS WITH A CUSTOMER COMPLAINT OF SEAT BELT DIFFICULT TO LOWER PAST STITCHING ON SEAT BELT WEBBING. *TT
Bulletin Number: 3608
INFORMATION TO UPDATE BULLETIN 05-06-01-001C FOR CRANKSHAFT HARMONIC BALANCER FRICTION WASHER. *TT
Bulletin Number: 3609A
HARSH 1-2 SHIFT, MALFUNCTION INDICATOR LAMP ILLUMINATED, DIAGNOSTIC TROUBLE CODE P0894 STORED IN PCM. *TT
Bulletin Number: 3630
FUEL TANK PRESSURE SENSOR READING. *TT
Bulletin Number: 3673
CRUISE CONTROL INOPERATIVE AND/OR MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE P0833 STORED. THE CONDITION MAY NOT BE ABLE TO BE DUPLICATED BY THE DEALER YET THE CONSUMER MAY HAVE A REPEAT CONCERN. *AK
Bulletin Number: 3761
WIPERS WILL NOT PARK. *TT
Bulletin Number: 3775
CROSS DRILL BRAKE ROTORS ROTATIONAL APPEARANCE. *TT
Bulletin Number: 3778
HEADLAMP LENSES HAVE LIGHT FOG OR MOISTURE. *TT
Bulletin Number: 609
HVAC MODULE SERVICE. *SC
Bulletin Number: 611
LOW COOLANT SYSTEM OPERATION. *SC
Bulletin Number: 612
CLOCK READS IN 24 HOUR TIME (MILITARY TIME) ON VEHICLES EQUIPPED WITH THE RPO US8 OR US9 RADIOS. GM TECH LINK. *TT
Bulletin Number: 701
FUEL FILTER REPLACEMENT. GM TECH LINK. *TT
Bulletin Number: 702
AVOIDING SCRATCHED HEADLAMPS. GM TECH LINKS. *TT
SIR LAMP ON AFTER DEPRESSING THE HORN FOR MORE THAN 5 SECONDS OR USING THE HORN TWO OR THREE TIMES IN SUCCESSION. GM TECH LINKS. *TT
CLOCK SETTING REVISION. *TT
AXLE VENT NOISE. GM TECH LINKS. *TT
Bulletin Number: 709
PERFORMANCE TIRES. GM TECH LINK. *TT
OIL LIFE SYSTEM RESET PROCEDURES - CARS. GM TECH LINK. *TT
Recalls for 2005 Chevrolet Corvette Coupe
2005 CHEVROLET CORVETTE
NHTSA Campaign ID: 06V181000
Component: STRUCTURE:BODY:ROOF AND PILLARS
Manufacturer: GENERAL MOTORS CORP.
Manufacture Dates: 03/01/2004 - 08/31/2005
Potential Units Affected: 30793
Defect Description:
IF THERE IS A COMPLETE SEPARATION, THE ROOF PANEL MAY DETACH FROM THE VEHICLE AND IT COULD STRIKE ANOTHER VEHICLE AND CAUSE INJURY AND PROPERTY DAMAGE.
Consequence:
DEALERS WILL INSPECT VEHICLES FREE OF CHARGE FOR POTENTIAL ROOF PANEL-TO- FRAME SEPARATION AND ADD THE SPECIFIED ADHESIVE FOAM OR REPLACE THE ROOF WITH ONE HAVING ADHESIVE FOAM. THE MANUFACTURER HAS NOT YET PROVIDED AN OWNER NOTIFICATION SCHEDULE. OWNERS MAY CONTACT CHEVROLET AT 1-800-630-2438.
Action to take:
NHTSA Campaign ID: 05V455000
Component: STEERING:HYDRAULIC POWER ASSIST:HOSE, PIPING, AND CONNECTIONS
Manufacture Dates: 07/01/2005 - 08/31/2005
Potential Units Affected: 123592
Defect Description:
IF THIS WERE TO OCCUR, POWER STEERING ASSIST WOULD BE LOST AND INCREASED STEERING EFFORT WOULD BE REQUIRED. ON VEHICLES EQUIPPED WITH HYDRO-BOOST POWER BRAKES, IT COULD ALSO RESULT IN LOSS OF POWER BRAKE ASSIST AND INCREASED BRAKING EFFORT WOULD BE REQUIRED. IF THE POWER STEERING FLUID SPRAY WERE TO SPRAY ONTO HOT ENGINE PARTS, AN ENGINE COMPARTMENT FIRE COULD OCCUR.
Consequence:
DEALERS WILL INSPECT THE POWER STEERING HOSE(S) FOR TWO SUSPECT DATE CODES AND REPLACE THEM IF REQUIRED. THE RECALL WILL BEGIN ON OCTOBER 14, 2005. OWNERS MAY CONTACT CHEVROLET AT 1-800-630-2438, GMC AT 1-866-996-9463, BUICK AT 1-866-608-8080, CADILLAC AT 1-866-982-2339, ISUZU AT 1-800-255-6727, OR HUMMER AT 1-800-732-5493.
Action to take:
NHTSA Campaign ID: 04V525000
Component: SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:HOSES, LINES/PIPING, AND FITTINGS
Manufacture Dates: 04/01/2004 - 08/01/2004
Potential Units Affected: 5225
Defect Description:
IF THE BRAKE FLUID BOILS IN A REAR BRAKE LINE, THE EFFECTIVENESS OF THE REAR BRAKE SYSTEM WOULD BE REDUCED WHICH COULD RESULT IN A BRAKE LINE LEAK AND LOSS OF BRAKE FLUID. IF ENOUGH FLUID LEAKS FROM THE REAR BRAKE SYSTEM SO THAT BRAKE PEDAL APPLICATION CAN NO LONGER BUILD PRESSURE TO THE REAR BRAKES. THE OPERATOR OF THE VEHICLE WILL EXPERIENCE LIMITED BRAKING WHICH COULD RESULT IN A CRASH.
Consequence:
DEALERS WILL (1) INSPECT THE LEFT ENGINE EXHAUST MANIFOLD CLIP FOR PROPER ALIGNMENT AND PLACEMENT ON THE BODY-MOUNTED STUD. IF INCORRECT, THEY WILL REPOSITION THE CLIP ON THE BRAKE LINES AND REINSTALL THE CLIP ON THE STUD; (2) THE DEALER WILL VERIFY THAT BOTH REAR BRAKE LINES HAVE THE PROPER CLEARANCE TO THE LEFT EXHAUST PIPE. THEY WILL REPOSITION THE LINES BY BENDING AS NECESSARY; (3) DEALERS WILL REMOVE THE MACHINING TAB FROM THE REAR DIFFERENTIAL HOUSING. ALSO, DEALERS ARE TO INSPECT THE BRAKE LINES FOR WEAR IN THESE RELATED AREAS AND REPAIR OR REPLACE IF THERE IS ANY SIGN OF WEAR-THROUGH ON THE NYLON OVERCOATING. THE RECALL BEGAN ON JANUARY 18, 2005. OWNERS SHOULD CONTACT CADILLAC AT 1-866-982-2239 OR CHEVROLET AT 1-800-630-2438.
Quick Reply: List of Service Bulletin Titles, and Recalls from NHTSA
