DIY – Rear Axle / Differential oil change, with pics – for FAQ
#261
#263
#269
there may be a t with a plug opposite the line. oor you may have to pull the line to drain I'm not sure after refilling you should run it and check the level as some fluid may be lost from the cooler and or lines
#270
Grand sport manual will not have a drain plug. there is a fitting there with a line out to the oil cooler pump. I have not looked a one closely.
Any consensus on how often the diff fluid should be changed. Seems pretty simple so every year? Or two?
#271
Premium Supporting Vendor
My personal thumbrules are about every 8 track days or so for my 02 Z06, and about 30-50k for a street car.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
#272
I don't think there will be a consensus answer. In my opinion, the change interval will vary based on what fluid (brand) you use (e.g. the quality of the basestock varies by brand), and your usage (e.g. track, street, dual use, etc).
#274
If your car is not making any noise, you can leave it alone. At some point, you should change the Diff oil anyway, but unless you have a high mileage car, you are fine as is. It really is a simple job though. I had no noise and did minestrone 27,000 miles. Simple DIY.
#278
1st Gear
Is TSB: #07-04-20-002A currently the latest?
How can I verify that TSB: #07-04-20-002A is the latest bulletin? I am having difficulty finding these on the GM website. 2005 Corvette Coupe
#279
Race Car Tech
https://www.corvetteactioncenter.com...drivetrain/27/
#280
Sorry to bump such and old thread, but I had a question. I have a 2012 GS and was wondering... can you get to the fill port from above the engine using a long tube. Seems easier to me than having to get a pump.
