3.15 Gear Ratio
1 Post
Cruise-In VII Veteran
3.15 Gear Ratio
I have had my baby for almost one year now and have been wondering about the 3.15 gear ratio that I paid extra for when I bought the car. The car was bought from the dealer showroom and during negotations concerning price I failed to ask my salesman what advantages there are to having this. I have done a lot of searching and reading on the forum and have not really had my question about this answered. I am not mechanically inclined so I really do not know anything about gear ratios. Are there any advantages to having this and if so, what are they. Will this affect gas mileage. My car is automatic. Thanks for any info.
It is a great option to have for the A4 auto tranny.
My C6 Vert automatic with a 3.15 rear ran a 12.57@110.67 with a 1.92 60' time.
The 3.15 rear is lower geared than the stock 2.73 rear which provides better acceleration.
Howard
Howard
Not much if any effect on gas mileage.
My 2005 C6 automatic with the 3.15 gets over 16mpg in the city.
My 2006 C6 manual tranny barely gets over 13mpg in the city and sometimes less.
Howard
Howard
Originally Posted by rick229
You will get less gas mileage with the 3:15's that the 2:73's. About 2-3 miles less.
Originally Posted by catbert
On a trip I get 2 mpg less with the 3:15 C6 than my 2:73 C5.
1 Post
Howard
Howard
A 3.15 geared car should get about 2-3 MPG less on the highway than a 2.73 geared car, but around town both will be about the same.
In the quarter mile a 2.73 geared car is probably about two tenths slower. It also won't feel as "snappy" off the line when driving around town as a 3.15 geared car does. I sure was happy when I checked the glovebox codes on my C5 and saw the G92 code for the 3.15s!
3:15's Better acceleration off the line but higher RPM's at freeway speeds. A little bit less gas mileage than 2.73's. I get about 22 MPG combined with 3:15's.
Does this mean your top end speed will be less with 3:15's vs. 2.73's?
I have a 2005 z51 a4 and I find down low these 315 gears to be very lazy . Im changing them to 342 and also putting a tci stall converter to give the car some life off the line.
Probably not. The Vette is more drag limited at the top end than gear limited. Top speed runs are not made in top gear because the motor won't support an overdrive transmission gearset...at least stock.
I am doing a 2.73 to 3.73 swap eary next month, and will keep the 2.73 just in case. I don't plan on installing a converter until I put a cam in it. At that point the converter might be required.
rambo
Originally Posted by rambo
I've heard this before and don't understand what it means. Please explain.
rambo
rambo
Check out the cool charts!
