Invisicord Connectors
I installed my Invisicord earlier and it looks great (need to fix my mirror cam thing now though). Only question I have is how far do the Invisicord pins go into the mirror? They went in about half way and I didn't want to force it but I want to make sure it is tight before I fix my mirror so I don't have to take it off again. I did a search but couldn't find any info on the Invisicord pins.
MONARTOR
one of mine went all the way in (black) and the yellow went halfway.I just pulled the wire bundle out of the back of the mirror.. was real easy to do that way
MONARTOR
Originally Posted by Tim06
Did the "half way" one fall out or anything or had it stayed. I havn't taken the harness off as the pins are in, just doesn't feel tight.
I've had several of their cords and some do not come with the leads squashed flat. They should be very flat then they seat all the way. I used a vise to get them flat. I think they need to work on their quality control.....
St. Jude Donor '09
Guys,
If a pin won't go all the way in, pull it out and try a different side of the wire hole. You will find at least one of the four sides where the invisicord pin will go all the way in.
Soon as I took delivery, that was the 1st thing I did.
I sat in the C6 pulled the wire harness out of the mirror.
Connected my radar detector.
The sales guy was like WTF R U doing?
I responded dont ask questions show me how to work the NAV.
Originally Posted by Indy-hp
Guys,
Guys,
Thanks a lot, Ill try it in a better spot of the wires. Was raining and I was at work so I didn't want to mess with it much. Im confident Ill get it as soon as the weather clears up.
St. Jude Donor '08
Originally Posted by mickeykelley
Waht exactly is this invisicord thing? Something to do with radar detector?
Mickey
Mickey
the cord from the detector goes straight to the back of the mirror for power....different lengths available depending on where you mount it....
I'm wondering the same thing. I just picked up my c6 and am looking to put a radar detector into it, but want it to look "clean" and not have cords all over. I guess this is the way to do it?
St. Jude Donor '09
http://t-rexsoftware.com/greatlakes/
http://www.invisicord.com/
Does anyone have a problem with the mirror "bouncing" up and down on rough roads. I have an escort and when I am really WOT the radar will switch settings or dim the display. When I hold slightly the top of the detector it really stops the shaking. I am thinking of getting a foam ball or something to put between the radar and the braket to take up the tolerance. Any thoughts
Look right above the up directional arrow on the V1, and you will see a clear vinyl bumper that I stuck on the mount. 3/8" in thickness, adhesive on one side, package of 9 costs $1.69 at Home Depot. I have 8 left, PayPal me $2, and I'll ship you a couple...
