Magnetic plugs
Magnetic plugs
Does anyone make magnetic oil, trans, and diff plugs? The only ones I can find are for the C5 not the C6. I found these at www.ecklers.com Will these plugs fit my C6 properly?
Forgot to add Ecklers part numbers...
Oil Plug #39805
Trans Plug #42114
Diff. Plug #42115
Oil Plug #39805
Trans Plug #42114
Diff. Plug #42115
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
The diff plug from a C-5 will fit a C-6. Don't know about the trans. I got a magnetic diff plug from Mid-America but I think Ecklers is the same.
Originally Posted by Another Yellow
You can get the 2007 oil drain plug from your Chevrolet dealer. I doubt magnetic plugs for the transmission or differential provide any meaningful benefit.
I remember seeing a post that showed a large magnet is glued to the inside of the tranny housing at the factory. Other folks may be able to confirm or deny. If it's true the magnetic plug might be overkill.
