06 Bose/Nav crackling door speaker (tweeter?)
Driver side speaker crackling:
Any body else experience moderate crackling from the smaller speaker (tweeter?) located in the door. Very noticeable when the route guidance system chick voice talks to me. The larger door speaker was erroneously replaced (under warranty) in an attempt to solve the problem. It goes back in next Tuesday, but I just wanted to see if anyone else had experienced this problem. Thanks!
I have a problem with the door panel which causes a similar sound.
The hardware is separating causing a vibration in about 3 spots. My 05' was built in April 05'.
Cruise-In VII Veteran
Just back from Gwinnett Place Chevy this morning. They quickly listened again, and had me back on the road in a matter of minutes. They are going to replace the 3.5" speaker (GM warranty). They had to order it so I will update after it arrives and is installed.
Location: . [Rotorhead] "You seem to be a douche. What I'm getting at is just STFU" [/Rotorhead]
St. Jude Donor '06 & '09 & '11
I thought I had a problem in my 06; now I realize its static. I have a bizarre kind of crackling (faint tinkling sound?) that occurs every day in the same 3 miles stretch of my commute. I never hear it anywhere else and its like clockwork; starting and ending in the exact same spot.
Got car back yesterday. "Unable to duplicate symptom with speaker". Said found no TSB for speakers. Incredible but predictable for this dealer (Circle Chevy NJ). As I was driving home crackling distortion as bad as ever (worse with certain frequencies---particularly piano) Dealer will have factory rep look at car in the next few days. Headley, did replacement of 3.5" speaker fix the problem?
I found a few songs (on CD) that really made the problem stand out and played them for the guy that checked my car in when I returned. Also, took it in in the morning when there is a lot of talking on the FM stations. It really stands out when people are talking on FM stations. Also if you have Nav, the guidance voice really amplifies the problem. My local dealership has a (relatively) fantastic service department. They are really thorough.
They had to order the speaker, so the work has not been done yet. I will post an update when it is complete. Good luck with yours!
That worked for me, but if it doesn't for you I guess taking the door panel off is next.
Curious
That is funny! I have a base model no bose, but the last few times i was out I kept hearing crackling from the passenger side. My wife couldn't hear it but I could. I told her to put her hand over it and it was gone!! I could assume that it is the speaker or attachment. Since i put it away for the winter I will address this in the spring and have it fixed!! Thought i was going crazy because i was asking her do you hear it and her response was no!! But i had her sit on my side and she could go figure!!
For me the problem was at first intermittent, most noticeable after about 20 minutes of driving. More recently speaker distortion was pretty much constant. Distortion would vary depending what audio frequencies were playing and the equalizer settings . For me, distortion was worst when listening to solo piano.
*****update******
Fixed at last! Fixed at last! Thank God almighty, it's fixed at last.
Short story: It was a defective driver-side 3.5" speaker. It was replaced yesterday. I literally drove around last night for hours just listening to music. Ahhhhhhhhhhh... There were songs I would skip on my ipod because they sounded so bad. Not any more! The expression "like night and day" does not even begin to cover it! I guess I didn't realize how bad it was since it had always been like that.
It took a little work (and two trips to the dealership) to get it fixed, but it has made all the difference in the world. Gwinnett Place Chevy really stuck with me and worked hard at getting the problem resolved. Ryan Harris with GP Chevy is a motivated and hard working "Service Advisor". If you are in the area, I would recommend scheduling service through him. Great guy!
esq and ckvette2007, good luck with this issue and your dealerships. If I can be of any help just PM me.
