LS3 Engine: 0-60 & 1/4 mile ET?
Old 01-10-2007, 12:58 PM
UTVOL06
UTVOL06's Avatar
Default LS3 Engine: 0-60 & 1/4 mile ET?
Ofcourse this is primarily a speculation thread, but assuming the LS3 coming to the 2008 model base corvette this year gets 25-50hp increase what kind of 0-60mph and 1/4 mile time improvements could we see? I know the C5 Z06 with 405 Hp and a lighter body achieves 0-60mph in 4seconds flat pretty much and as low as 11.8_ seconds in the 1/4 mile (Stock).
Can we expect the base corvette to pull similar numbers with the new engine even though it weighs a little more than the C5 Z06?
Ofcourse we haven't seen really any Torque numbers yet?
Thanks for any input!
P.S. thanks Moderators
Old 01-10-2007, 03:22 PM
LS1LT1
LS1LT1's Avatar
Too soon to tell, the car might be rated higher (say 425hp+-) but in reality with the newer power rating system it might not actually be much higher than the power that the current LS2 generates.
Different standard of measurement and all that.
Old 01-10-2007, 04:00 PM
k0bun
k0bun's Avatar
Location: NJ..."the way I saw it, everyone takes a beating sometimes."
no...
Old 01-10-2007, 04:12 PM
burtonbl103
burtonbl103's Avatar
St. Jude Donor '06-'07-'08 & '12-'13
The rear handel delete will ad 15 hp
Old 01-10-2007, 04:21 PM
LS WON
LS WON's Avatar
Default New news to me
What is the LS-3 engine? A new engine for the 2008 Corvette? What other changes to expect.
Old 01-10-2007, 04:25 PM
LS1LT1
LS1LT1's Avatar
Oh yeah it's the latest craze, everybody's talkin' about it.
6.2L V8, new colors, maybe some new wheels too.
Nothing etched in stone yet but it looks likely.
Old 01-10-2007, 04:31 PM
LS WON
LS WON's Avatar
At this rate I'll never be able to keep up.
Old 01-10-2007, 04:36 PM
Vette_DD
Support Corvetteforum!
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
You've got to come back here more often than once a month to keep up.
http://forums.corvetteforum.com/show....php?t=1532281
Old 01-10-2007, 04:39 PM
UTVOL06
UTVOL06's Avatar
Well, hopefully the additional power will give us instead of 0-60mph in 4.3seconds...maybe 4-4.1seconds. maybe shave 0.2 tenths off the Quarter mile.
Old 01-10-2007, 05:11 PM
LS WON
LS WON's Avatar
I'm trying to kick this addiction. I'm going cold turkey
Old 01-10-2007, 05:16 PM
jschindler
jschindler's Avatar
0 - 60 times have become meaningless to me on todays performance cars. It is all about hooking up. The only times I want to see now are 1/4 mile - both ET and trap speed. By looking at both, you get a better idea of how the car performs in the real world of street driving, where a perfect launch is not critical to understand what the time is telling you.
Old 01-10-2007, 05:19 PM
LS WON
LS WON's Avatar
That's what they have automatic trannys for
Old 01-10-2007, 05:32 PM
BADC64GO
BADC64GO's Avatar
My guess 12.0 116 mph
Old 01-10-2007, 05:40 PM
NORTY
NORTY's Avatar
The LS-3 is already in the GMC Denali/Caddy Escalade and making 400hp/417tq in that config. Just for comparison purposes,the LS-2 in the Silverado is 367hp/375tq. If this is realistic, then it stands to reason that the LS-3 will develop 436hp/445tq. This also tells me the LS-03 will not rev to 6500rpm. Maybe to 6000? Don't forget VVT also. We won't get into AFM or DI here.
Old 01-10-2007, 05:44 PM
LS1LT1
LS1LT1's Avatar
As a budding young car enthusiast in the late, late '70s/early '80s all I looked at was a car's 0-60 time...but as time wore on and I gained a little more knowledge I learned to appreciate the other yardsticks of acceleration.
Old 01-10-2007, 05:50 PM
LS1LT1
LS1LT1's Avatar
True, though the Escalade/Denali motor is actually called L92 (makes 403hp I think) and that tall truck intake is of course different than what the C6 would be getting as likely the cam and compression ratio would be as well.
And I don't think the motor in the Silverado is actually considered an LS2 though they all share some resemblence/similarities.
Old 01-10-2007, 06:00 PM
NORTY
NORTY's Avatar
True, breathing differences will be there as well as cam grinds,comp ratio. The Silverado gets an aluminum block 6.0 liter with hp#'s stated above. It also gets Variable valve timing. I don't know if the goal for VVT is bottomend torque or emissions or midrange punch. I doubt it's for topend rush. (At least in a truck config.) You're right the Escalade is rated @ 403hp while the Denali is 400hp. (Probably less restrictive exhaust or intake.) The thing that surprises me most is the hp/tq #'s are reversed. It tells me this engine will not rev beyond 6000.
FWIW, I see AFM as a gimmick this isn't necessary on the Corvette. (It won't be wanted either, I'm sure.)
To LS3 Engine: 0-60 & 1/4 mile ET?
Old 01-10-2007, 06:25 PM
LS1LT1
LS1LT1's Avatar
Good point, we might see a reduction in redline/rpm range with the new motor possibly.
I agree, due to it's weight, gearing and drag coefficient the Corvette still really shouldn't need AFM/DoD, even with a potential power increase.
Old 01-11-2007, 03:16 AM
LS WON
LS WON's Avatar
Corvette has alrways had the advantage in its lighter weight and aerodynmics over competitors.
Old 01-11-2007, 08:11 AM
AFVETTE
AFVETTE's Avatar
For track used I'd hate to see ANY reduction in RPM's. Down shifting from 4th to 3rd for corners with 400 to 600 less RPM's could really add seconds to your lap times.
That doesn't sound good or fun. I hope everyone is wrong about a reduction in the redline. And 0-60, 1/4 times are meaningless to me as that is as much a by product of the driver than the car. I recall getting my head handed to me in my 03 Z06 by a punk in a Mustang SVT Cobra at a Test and Tune night purely due to the fact I had a hard time launching. Was his car faster, technically no, but on that night and place he had time slips and photo's to show on some Mustang forum.
Tom
Quick Reply: LS3 Engine: 0-60 & 1/4 mile ET?
