Build Date
Old 01-13-2007, 11:11 PM
John's '07
Support Corvetteforum!
John's '07's Avatar
Location: I don't deserve this car, but I have arthritis and I don't deserve that either. Bay Point, FL
St. Jude Donor '06-'07
Default Build Date
Where do I find it?
Old 01-13-2007, 11:20 PM
ben dover
ben dover's Avatar
Location: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
It can usually be found in the right front wheel housing in chaulk.
Old 01-13-2007, 11:23 PM
Zymurgy
Moderator
Zymurgy's Avatar
Received 15,066 Likes on 6,168 Posts
The month and year (and some say the day also) are on a sticker on the driver's door. Mine only has the month and year.
Old 01-13-2007, 11:41 PM
John's '07
John's '07's Avatar
Okay, thanks, I found the sticker on the driver's door with the date 10/06, but just some scribbling that looked like initials on the wheel well.
Old 01-13-2007, 11:50 PM
Vette_DD
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
Give your VIN to someone with access to the GM system and they can look it up for you. Your dealer can do it.
Old 01-13-2007, 11:53 PM
2008corvette
2008corvette's Avatar
That's what I did, I now know the exact day my car was built.
Old 01-14-2007, 01:28 AM
siffert
siffert's Avatar
It can usually be found in the right front wheel housing in chalk
Not nessarily true. My wheel housing chalk says 8/15/06 when in fact the true blue build date for my 2007 coupe via the GM system is 8/22/06. I think that chalk is perhaps the date the housing was delivered to Bowling Green
Old 01-14-2007, 09:41 AM
talon90
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
As has been said, the only way that you will get your actual build date is from the GM vehicle information system. The sticker on the door jam will give you month and year. The information chalked in different places on the car is specific to when the part arrived at the plant and or when it started (the part) on the line. You also cannot get your build date from your build sheet. The dating on the build sheet is when the order to start the build was received at the plant and this can vary by a few days to a few weeks from the actual finish of the car (build date).
Paul
Old 01-14-2007, 10:56 AM
siffert
siffert's Avatar
Thanks for clearing that up!! Which is what I thought about the chalk.
To Build Date
Quick Reply: Build Date
