Callaway Honker precut shroud
Cutting the shroud & pop riveting the filter frame to it is about the easiest/quickest part of the installation.
The hard part is getting the shroud in and out - and you'd have to deal with that even with a precut shroud.
Bob
Bob
Removing it and replacing it, and you'd have to deal with that even with a precut shroud, is what is time consuming.
If you just want a stock, uncut shroud, for later, those can be had from GM Parts direct.
I asked the same question of Callaway and they wrote back and said they do not have a precut shroud. However, I agree with everyone here, cutting and pop riveting is the easy part. If you want a new shroud (I had to get one because my original shroud was already cut up in the wrong areas), get one from Gene Culley. Mine was $31 shipped to my door in 3 days.
Yea, unfortunately, I think Gene doesn't make much money on this particular part because he uses a standard $7.50 shipping charge and I'm betting this cost more to ship.
When I installed mine I was more than happy to cut the shroud after I got it out as payback. Big hands and litlle sharp plastic things dont mix.
Better instructions with blow-up pictures of the fasteners they are referring to would help a lot with the install of this device; Also, I suspect an inexpensive tool could be fashioned to help remove the shroud; there are a lot of overlapping pieces on the bottom of the shroud that are the same black color and it is hard for a novice to know what is connected to what.
