30,000 mile service
Old 02-24-2007, 03:17 PM
rockstar
rockstar's Avatar
Default 30,000 mile service
Being lazy I have not yet read my entire manual. Is there a major service required at 30,0000 miles as on many import cars?
Old 02-24-2007, 03:30 PM
johnodrake
Moderator
Support Corvetteforum!
johnodrake's Avatar
Received 3,578 Likes on 1,619 Posts
Scheduled Maintenance
When the CHANGE ENGINE OIL message comes on,
it means that service is required for your vehicle. Have
your vehicle serviced as soon as possible within the next
600 miles (1 000 km). It is possible that, if you are driving
under the best conditions, the engine oil life system may
not indicate that vehicle service is necessary for over a
year. However, your engine oil and filter must be changed
at least once a year and at this time the system must be
reset. Your GM Goodwrench® dealer has GM-trained
service technicians who will perform this work using
genuine GM parts and reset the system.
If the engine oil life system is ever reset accidentally, you
must service your vehicle within 3,000 miles (5 000 km)
since your last service. Remember to reset the oil life
system whenever the oil is changed. See Engine Oil Life
System on page 5-23 for information on the Engine Oil
Life System and resetting the system.
When the CHANGE ENGINE OIL message appears,
certain services, checks, and inspections are required.
Required services are described in the following for
“Maintenance I” and “Maintenance II.” Generally, it is
recommended that your first service be Maintenance I,
your second service be Maintenance II, and that you
alternate Maintenance I and Maintenance II thereafter.
However, in some cases, Maintenance II may be
required more often.
Maintenance I — Use Maintenance I if the message
comes on within 10 months since the vehicle was
purchased or Maintenance II was performed.
Maintenance II — Use Maintenance II if the previous
service performed was Maintenance I. Always use
Maintenance II whenever the message comes on
10 months or more since the last service or if the
message has not come on at all for one year.
There are additional requirements at 25K mile increments (25, 50, 75...) See your manual
Old 02-24-2007, 04:13 PM
Vette_DD
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
At 25,000 miles, the owner's manual says the fuel system should be inspected for damage or leaks and the exhaust system should be inspected for loose or damaged components. Both of these should be done every 25K miles.
Old 02-24-2007, 04:22 PM
not08crmanymore
not08crmanymore's Avatar
every car everywhere has some sort of service around that mileage.
Old 02-25-2007, 08:21 PM
Lightning Coyote
Lightning Coyote's Avatar
Old 04-15-2007, 09:55 PM
z06Bigbird
z06Bigbird's Avatar
I routinely change tranny fluid at that point.
Ed
To 30,000 mile service
Quick Reply: 30,000 mile service
