Xxx-pipes???
In essence they smooth out the exhaust gases (or pulses) as they flow through the system. You have to remember for whatever reasons the Corvette engineers didn't install a TRUE DUAL exhaust system, they choose to "connect" both exhaust banks exhaust gases together where the H is mixing both the left and right hand pulses. In addition some claim they increase HP/TQ by a few points. The main reason most folks opt to install an X-pipe is to "tone down" some of the nasty side affects of installing ANY after market cat-back system. Namely resonance or drone and it will cut some of the popping, snapping etc on decel.
I guess you could say it "tunes" the exhaust flow slightly better than an H-pipe.
Hope this helps.
Tom
Hope this helps.
Tom
